Ecoflow delta EF1500
Just a stab here. If you are familiar with the ecoflow R600 Pro kickstarter campaign. This is a EF1500 add on battery expansion pack. Brand new. Kickstarter special and is no longer made. The best battery you can buy and 1/5th the weight of an AGM equivalent
1500Watt, 120amp Hour pack. Can be used alone or with the R600 pro.
24 V direct connection terminals, R600 expansion port, 12 V DC input and output and Solar input
This is LiFePo4 chemistry, 3500 charge discharge cycles and 10yr battery life unlike li-ion which is only 500 discharge cycles.
3yr warranty directly from Delta Ecoflow. Specs in pic below
$900, shipping extra
anoopkrishna.r@gmail.com
bdpkauai
