edgestar 43qt actual measurement please!!
freshlikesushi
Free Candy
IIs there any way anyone can do an actual real world measurement of the bottom of this device?
Im going to have a piece of steel bent up here at work to make a sliding tray for it, and need to know the actual width of the bottom. Is it a vertical side face or does it venture outward as it heads to the top of the fridge. Also actual length. Plan is to make a tray basically. then use 2 2"x2" L stock to bolt the hinges to and use the sides of this tray to mount the other half of the hinge to. any help would be appreciated
4x4junkie
Mine measures 16-5/16" x 23-3/8" (not including protrusions such as power plug, drain plug). Sides are straight (vertical).
Xterabl
Yeah, it has the following protrusions: handles on the left and right sides; lid latch on the front; lid hinges on the back.
Let me know if you want measurements.
freshlikesushi
Free Candy
I was just worried about the base. above 2" or so it doesn't really matter on the sides. I made the sliders yesterday and the fridge will be here today ill finish up the slide
Petersmithinak
