Hillbilly Heaven
I am working on something that I think I want to use some type of gas assist spring to hold it in 2 positions.
Is it possible to hold in 2 positions?
I have attached a rough sketch of what I want to do. The dimensions at this time are not important, that is just the basic concept.
The two vertical parallel black lines are pivoting links. The red line would be the gas spring or whatever. It needs to be held in both the bottom position as well as the up position.
Whatever I use needs to fit within the vertical rectangle area. There are no attachment points available outside that area.
![Swing measurements2.jpg Swing measurements2.jpg](https://expeditionportal.com/forum/data/attachments/381/381957-a394be52184d9268c5a989a4ef1b12db.jpg)
