Eezi-awn 2000 Question
skephart
I was looking at the Eezi-awn 2000 awning at the Equipt web page and was wonder how it installed. I check the Eezi-awn web page and could not find any information. I would like to use the factory rack on an Xterra. Also, any comments on how well it works. $600 price range is not cheap - but sometimes you get what you pay for.
Bergger
While I don't have one I've seen them and they appear to be of very high quality. I own an one of their tents so I imagine the quality is just as good. If I were you I'd just call Paul at Equipt and I'm sure he can tell you if it'll mount or not.
Martyn
The 2000 awning comes with brackets.
I believe there are two of them formed from an aluminum extrusion. The awning slides into the circular section at the top. The back of the awning is flush against the vertical portion. The awning is held in place with the nut and bolt in the lower section.
The hole in the vertical is for attachment to a rack, but I'm sure there are many other ways to attach it.
The 2 meter awnings are in stock at AT
skephart
Thanks Martyn. What is the weight of the awning? I am concerned about too much weight up top.
ShearPin
My 110 came with an Ezi-Awn awning. I haven't owned the vehicle long nor have I been on as many trips as I'd like.... My experience to date is that the unit is very well made. Did a two night trip this past weekend and had heavy rain and a lot of sun. I'd always wanted an Awning on my old Rover and never got around to it - this trip had me kicking myself I hadn't installed one long ago.
Set-up is more involved then the Hannibal awning my brother runs but it is still a one man operation. I'd recommend it over the Hannibal due to the ability to raise or lower the outer edge with the vertical support poles. The Hannibal design requires movement of the truck to maintain shade throughout the day. By lowering the Ezi-Awn it is possible to maintain shade except during sunrise and sunset hours.
Lowering the outer edge is also a benefit in heavy rain. My brothers Hannibal is a rigid design but it will collect water, sag, and eventually drip. Lowering the Ezi-Awn obviously lets the water run off rather then collect.
Henry
www.4x4freedom.com
tdesanto
They're very lightweight compared to the amount of shade they give you. I'm guessing somewhere between 12-15lbs.
I installed one on my AT Horizon.
You can also get their recvee panels (the panels that cover the 3 open sides to create a shelter).
Martyn
The 2.0 meter awning weighs 27 or 28 lbs, and provides 45 square feet of coverage.
skephart
Thanks everyone for the help. It looks like the Ezi-Awn it the way to go. It will definitely make my wife happy. I just need to get my second battery first.
petrolhog
Anyone have any photos of the awning up close (Opened). Are they similar to Camping lab or ARB (ie. poles and tarp) and the way that they are set up
Other than the actual awning case being a hard shell vs. soft shell (Camping lab and ARB awning) Thanks.
benedmonson
Disabled Adventurer
I've had the 2.2 meter Ezi-Awn on my LR3 for several very long trips now and couldn't operate without it!! I'll see if I can get a pic uploaded today from the Baja Trip we just got back from. When you're not using it, you don't even know its there!!
V45W_Proto2.5
