Eezi-Awn K9 Camp Table, Large $150 OBO... Delivered if you are between DC and Moab
NomadOnWheels196
I am trying to downsize and I bought this table but never used it. It might have a couple of small scratches, but it is basically new.
This table retails for $320.
The Eezi-Awn K9 Camp Table, made from stainless steel and aluminum, is a lightweight and compact folding table that stores easily under you Roof Rack with the Table Mounting Kit, saving valuable interior storage capacity. Available in multiple sizes, these tables provide an excellent place to prepare and serve meals, fix your fit, hold the lantern, and generally avoid placing your stuff in the dirt. The surface is made of a dimpled and polished stainless teel surface with complimenting black polycarbonate corners, and is supported by a set of black, powder-coated aluminum folding legs. The dimpled surface not only looks great, but it increases the material rigidity, allowing for a thinner and lighter surface. The aluminum frame and legs are light and corrosion resistant.
Features
-Lightweight, Stainless Steel Dimpled Surface for Strength & Ridigity
-Polished Finish for Rugged Good-Looks & Corrosion Resistance
-Durable, Boxed Aluminum Frame
-Powder-Coated Aluminum Ladder Frame Legs
-Stainless Steel Leg Braces & Hardware
-Compact Legs Stack when Folded to Reduce Thickness
Specifications
Dimensions (Open) 44.5" L x 27.5" W x 26.5" H | 1130mm L x 700mm W x 675mm H
Dimensions (Closed) 44.5" L x 27.5" W x 2" H | 1130mm L x 700mm W x 50mm H
Weight 13.5 lbs | 6 kg
Material Stainless Steel Table & Aluminum Legs
jacob_lashell
