Egret in Flight
Every Miles A Memory
Got a cool shot of an Egret today that you dont normally see. This bird was begging for food on a balcony, but the wind was blowing pretty strong, so it would sit in the wind hovering only a few feet in front of my lens
Great pics! How's the weather been in the lower Keys? The wife and I are considering flying down in the next couple of weeks.
We're in the Upper Keys...LOL
1 Hour west of Gainesville right below the Suwannee River, but up untill yesterday, we've been in the 80s. Woke up this morning to a cold front that brought in some frigid temps. Really strong winds and 50 degrees has us all bundled up:ylsmoke:
Once again, amazing pictures! Talent and perfect timing, what a great combo.
My wife and I will be booking a room with you guys later in the winter/early spring. We've covered much of Orlando and the East coast. But in late Feb we are going to visit the lower keys for the first time to get away from Ohio. I want to hit the west coast when it's warmer and just relax.
Ok, you have to give me some pointers here, those shots are amazing. The fact that the bird was hovering near your balcony helps a lot, but what settings do you use? I'v been trying to copy your birds in flight when ever I get the chance, but the biggest problem I'm having is getting the exposure. Obviously the sky is normally (other then white birds) much brighter, so even on spot meter I wind up with a silhouette and have to compensate, by which time the bird is gone. Are you doing a manual exposure that you metered before hand? I haven't played with manual too much for this as I'm not fast enough at changing the settings. Also, what f stop and shutter do you use to have sufficient depth of field but still stop a birds wings while flapping?
Thanks!
Clark White
Hey Clark, thanks for the compliments on the photos and my Birds in Flight stuff. Its been one of those things I've been working on since we moved to Cedar Key and have a front row seat to some of the best birding around
When I'm shooting BIF, I try and keep my Aperature (F-Stop) pretty low to blur out the background and be able to keep my Shutter Speed pretty fast to stop the action. Keeping a low Aperature also helps in making the subject pop out of the image.
When shooting birds, I almost always shoot in AV mode, with Canon Cameras, which I shoot exclusively, but I think its called A Mode with the Nikons if that's what you're shooting.
I never shoot with the birds having the sun behind them, always with the birds flying into, towards or away from the sun. This allows the birds to be lit properly without the sillohette you're talking about.
If you're following the birds, you simply follow them while they're flying and stop taking photos as they pass through the sun. Wait till they get where the light is in your favor again, and start shooting again. But you need to have followed them the entire time while keeping them in focus or you'll miss the shot.
This involves some studying of your subject to know what they're going to do or at least know they're tendencies. When shooting BIF, I always have the Focus set to the Al Servo Mode which allows you to track a moving subject while keeping it in focus.
If you havent figured it out yet from watching them long enough, when watching a bird that is perched on a branch and it bends forwards and relieves itself, this means it's ready to take flight. They always lighten the load right before they launch...lol
This little bit of information has got me some awesome shots of various birds leaping into flight simply because I knew what they were going to do right after they let the load go.:)
As for metering, I always keep the camera set to center focusing which makes sure my bird is metered properly and exposed how I want it. For the bird at least. I'm not as worried about how the background is exposed, but as long as the bird or subject is exposed properly the background can usually be fixed afterwards.
This is something you have to remember while shooting things that are moving really fast. I'm more worried about getting my subject focused and captured so you cant always get a perfect image like you can with a stationary subject like a scenic or landscape scene.
Does that explain some of the techniques used to capture them? I'm strictly a novice at the Birds in Flight topic, but I've been studying many of the forums that go into great detail in this subject.
Hope that helps
Thanks! For an "amateur" you sure do take some awesome photo's! Sounds like about what I had come down to trying, I really need to work on getting a better angle. I was hoping maybe you had some magical trick because the one shot I always end up having a chance at always has the bird with either the sun, bright cloud, etc. behind it. I'll have to make sure I use the constant focus as well, I think I may have been neglecting that setting. How fast of a shutter speed do you find is normally necessary to get a good clear shot? I'm using the Nikkor 70-300mm f 4.5-5.6, so I can't get that low of an f stop, but I don't want any higher ISO then I really need either.
Thanks!
Clark
Thanks Trevor!
Clark, one thing I try and do with the birds os go for different angles. With a longer zoom, you can try and stay zoomed in so your angle looks more like you're face to face with them.
Even if you're not.
If I'm really wide, then I tend to be looking up at them, and that's how everyone elses shot looks, but if I'm zoomed in, the angle lessens and looks like I'm right there with them.
Hope that helps.
Pat, thanks for passing on your tips. That Egret shot is awesome. :wings:
Now, can you please send me all you super telephoto lenses and a large cage full of beautiful birds so I can practice here in the desert. I promise to take good care of the birds and return them to you.
I can't make the same promise on the lenses. :elkgrin:
empireoverlandza
