badfysh
Hello,
I need help from an experienced electrical engineer or otherwise that can explain how to set this up.....
I am replacing my "reverse" light with two LED work lamp style lights attached to my rack. I also want to add a switch so that when I am in the back working, I can turn the lights on. So Ultimately I want one (two total) light system for two functions.
1. On when I am in reverse.
2. On when I flip a switch in the trunk to use as a work light.
Is this as simple as adding another +12v line with a switch to the light? Or will this damage something? It seems to me that 12v coming form the system is just that, and whether it comes from one place (the car reverse) or straight from 12v with a switch, it shouldn't matter...but I don't want to fry the computer or burn the car down. What if I leave the switch on and then forget then go to drive away and put it in reverse ie: two 12v sources in parallel running to the same light, again, shouldn't matter right? See, I need help.
Currently I have a "work lamp" attached to the rack and it is just scotch locked onto the reverse light pig tail (reverse went away with the factory bumper).
A diagram would be helpful if this setup is anything beyond just simple wiring.
Thank you.
Thank you.
