mobydick 11
So I am just installing the electrical system in my Gear trailer . this is my question . when installing the inverter there is a second ground lug . can this be hooked to the negative terminal ? I will give a run down of what I have so far . two T105 6V in series 12V right . this feeds and master shut off then a 80 amp breaker ,positive to 700 w inverter ground from inverter back to first battery negative. I was not intending to ground the batteries to the trailer as it is aluminum . but can the second lug go on the negative post or should it go to the trailer . Thanks
