SportsmanJake
In the past year I have added a lot of electrical accessories. I have wiring for 3 sets of lights, CB radio, and a dash cam. All of these accessories come together under the hood where my Blue sea fuse block and Hella relay box are located. Installing these was usually done in large chunks of time where I was working by myself. I always underestimated these projects and was eager to get them done. That being said, I always took time to make sure the system was safe. But it is very messy. I have wires everywhere and want to clean up my system.
Phase 1: installing all the above stuff.
Phase 2: Fixing any shortcomings from Phase 1
Questions
I think I am asking the right questions as far as improving my setup. Thanks for any help.
Questions
- Why can I not find bonded 12 awg wire to use on my truck?
- Can anyone recommend a good pos/neg waterproof plug/connector for 12 awg wiring? I have lights on my Leer cap and do not want to cut and resolder each time I remove the cap.
- Can anyone recommed a good negative/ground bus strip to use on my setup? I want to ground 6 wires to this bus that will be grounded to the frame.
- Is it okay to use different size wiring on the same relay? (Example: 12 awg running to battery, 12 awg running to lights, 16 awg running to switch)
- Why do people use the Blue sea fuse boxes? I feel like inline fuses take up a lot less space.
- I heard I need a resettable fuse or circuit breaker to go inline the 6awg wire that runs from my battery to the fuse box. Any recommendations?
