Engel MT60 Combi fridge side temps?
Redline
Likes to Drive and Ride
I just received a new Engel MT60 Combi from Adventure Trailers (thanks AT).
It seems when the freezer side is set to a refer temp, the refer only side that is supposed to be regulated to 40-degrees is too warm, in the high 50s! If the 'freezer side' dial is set to 2.5-3 to get the freezer below 0-celsius or so, then the refer is around 42-degrees.
Not sure what the issue is or if that is how they all are? If so it negates using both sides for refrigeration as is supposed to be an option.
I'm playing with it. The owners guide is small and provides no clues. One idea I had was removing the internal lid on the freezer side to see if that helps equalized the temps?
I know there are a few MT60 Combi users out there in ExPo land... at what temp do you set the dial to use both sides as a refer? Differences in temps between the sides?
James
Redline
temp test update
Did a test with the 'freezer' side lid removed and the thermostat dial set to #2.
After a couple hours
Freezer side: 0.2 Celsius ( 32.3 F)
Refer side: 11.4 Celsius (52.5 F)
Temps taken with Engel dual zone.
