Ev-2 2019 144" 4x4 Pebble Grey Build out!
freshlikesushi
Free Candy
EV-2 / Ribault
130,000
Exterior:
Van Will Include:
Factory Black Steel Wheels
265/75-16 BFG Ko2 Tires
Agile Offroad Clearance Fender
Terra Wagon Fender Trim
Terra Wagon Slider Trim
Owl Vans Driver Side Tire Carrier
Matching Spare Tire
Flarespace Flares
Tern Overland Window in Driver Side Flare
AMAuto Slider Window on Driver side
FreedomVanGo Aluminum Roof Rack
Dometic 9500 Manual Awning
2 100 Watt Renogy Solar Panels
2 Maxxair Deluxe fans with remote
Electrical:
Goal Zero Yeti 3000
Solar Charging Input (12A tested max)
Link Alternator Charging System (50A tested max)
FreedomVanGo Van power integration package
All Wiring is:
Marine Grade Wiring Throughout
Heat Shrink Connections
Abrasion Resistant Covering where required
Correct AWG for loads and runs
Multiple 12v and USB ports throughout
Ceiling Lights with Dimming, Individual shutoff, Red color option
Goal Zero 12v regulated Plug for Fridge
Dometic CFX 50
2 110 V Outlets in Passenger Area
Dimmable reading Lamps in sleeping area
Interior:
Aluminum Framed Upper Cabinet
Aluminum Framed Galley Unit
Aluminum Framed Fridge Unit with Dometic Slide and CFX50
Aluminum Framed Bed @ 34” height
Aluminum Framed Opening Wheel Well Boxes
All Cabinetry skinned with cabinet grade ½” wood and laminate with PVC edging
Luxury Vinyl Plank Flooring
Custom Powdercoated Tig Welded Aluminum entry trim
3m Thinsulate floor insulation
3m Thinsulate Wall Insulation
Hushmat Sound Deadening
Adventure Wagon RUV Interior Kit
Two MaxxAir Fans
Ripplewear Custom spec Front, Windshield, Rear and back window covers
Custom Diamond Stitch Flare interior Liner with foam
Flarespace Flare Trimrings
Ikea Queen Mattress
CFX50 Fridge/Freezer unit
Factory Mercedes Swivel Seats
5gallon fresh and grey water tanks in galley
Dometic Sink/Stove unit
1lb propane tank plumbing with bracket in galley
FreedomVanGo Molle Panels on rear doors
5.11 and Blue ridge Overland Gear Molle Pouches
This Is a well equipped full build on the fantastic new 2019 Chassis from Mercedes. At a 144” wheelbase, it is perfect for a daily driver, or dedicated camper. Pretty much all the bells and whistles, and we can add more if you need! Designed for the roadtripper with a low to medium power requirement powered from our tried and trued Goal Zero 30000 system that charges from solar and the alternator to make sure you always have power. Lots of aftermarket goodies preinstalled with the option to have more!
We are a builder located in Jacksonville Florida, who have years of experience making amazing vans to get you on the road faster. Let us help you make your dreams come true and live life without limits!
EV-2 Ribault by Grant Wilson, on Flickr
Marka1
