Expedition Motorcycle Trailer
07megacab
Greetings everyone! Calling on people with experience pulling a small expedition style trailer. I'm thinking of building a trailer similar to the flatbed that AT used to make. The main purpose would be to carry 2 dual sport motorcycles and possibly have a 25ish gallon water tank. The wife and I are taking a trip to Alaska from NC this fall and would love 2 bring the motos. I have used a dual hitch hauler before and I didn't really trust it. Any tips from people with experience in this are would be greatly appreciated!
1. How do people like the timbren axle less suspension? It looks very durable, but not super soft.
2. Do you think it would be worth it to match the truck tire size? I drive a 3500 on 37s. A 37" on a trailer seems ridiculous to me, but I also see the value in everything matching. Does the size of the trailer tire have a massive effect on efficiency?
3. Box trailer vs flatbed? I also like the idea of the bikes being enclosed and out of the elements. I've never had a enclosed trailer. Would the build quality survive rough roads for its life? I live off of a rough steep mixed dirt/gravel road and would really like a trailer to survive a long time. I could always just put covers on the bikes on a flatbed.
Oscar Mike Gulf Yankee
Sorry, I can't tell you anything about timbren axles except they cost much more than a tube axel with springs.
As to matching tires; I have 4 trailers, none have "matching" tires to any of my tow vehicles. Not sure what all my tires sizes are but none are even close to 37", right now none are even an "AT" tire. Your bike trailer is about the size of my tilt bed trailer (originally made for a riding lawn mower) or my TBT.
My enclosed trailer (ET) is 14x6x6.5, it tows my trike and is being modified for camping/mild overlanding.
As to "matching" tires, I'm considering putting 265 BFG KO2's on three wheels, 2 on a trailer and a spare, depending on conditions I'll swap wheels between the TBT and the ET. May consider that if you get another trailer behind that 3500.
A larger tire, even monster 37's wouldn't be a hill for your tow vehicle, after you're rolling you probably wouldn't know that trailer was hooked up. Even taking off from a stop light you'll forget it's back there with your rig. I doubt you'll even notice a difference in your MPG, but it won't help.
Advantages of large matching tires to a tow vehicle are obvious, but do you need them? No, I'd think it's a nice to have and far from a must have, so long as you have spares. Now that depends on your intended use (an answer I see often on this site), taller tires will increase ground clearance, so I would think that having your trailer frame at or near the height of your tow frame would be optimal. And, everyone knows taller tires will increase the approach and departure angles.
I'd say there are hundreds of threads here about tires, comments from those who know much more about them I do. What I do know is that bigger is not always better, that tires and wheels play on the suspension, it can get pretty expensive. As long as your trailer tires track in the same rut as your tow vehicle, the closer the better, you should be good, the tires don't have to be the same size as the tow vehicle, but it's nice if they are obviously.
Enclosed or flatbed, which is better? Same answer, it depends. Intended use? Not defining my use is how I ended up with 4 trailers!
OK, one is a 26' boat trailer, can't help that. Had I built my TBT a bit larger I wouldn't have needed the ET to haul the trike;
But, an ET protects the cargo, can be used as a hard sided camper (like in bear country).
An ET provides security for cargo, a tarp only hides it. (and, I would not put a tarp on my trike!)
An ET can carry more stuff, not in weight but more items, you can pack it to the ceiling if you stay safe with the weight and loading.
An ET can be weather tight, cargo will be dry and clean, if it is insulated you can keep cargo warm or even cool for the dog.
Down sides; an ET can only carry what fits trough the door(s)/ramp. While tear drops are cool, they are very limited.
So, size matters, it's not a good thing to tow a load wider than your tow vehicle, while you can go taller there are a few issues.
Sidewinds on a highway can wag the dog, the stronger the wind the less fun you'll have with an ET.
If the ET isn't really in the slip stream of your tow vehicle, headwinds will slow you down and your MPG will drop.
I've had flat front cargo trailers and a "V" nose has better stability down the highway, reduces the effects of headwinds and even a bit of sidewinds.
An ET can be an "eye sore" in some neighborhoods, they are more visible than a flatbed of equal size, so consider where to store it.
If your ET is tall enough to walk in and have greater utility but, your rear visibility behind your trailer is gone. You might need towing mirrors
and a review camera is on my list of trailer mods.
Now, many of these wind and visibility issues will apply to a flatbed with a heavy tarp, depending on the height of that covered load, as it becomes a sail.
As to build quality, got no idea how you drive! If you go blazing down a rough road in that 3500, if you don't tear up a trailer your cargo might get trashed.
All my trailers are steel, they are almost bullet proof (depending on the caliber). I wish my ET was aluminum, but it's durable.
You mentioned enclosing your trailer, I would if I were you, so the build quality is up to you.
The 2 big advantages of an ET are security and being weather tight, that alone is worth the build, IMO.
All the best! OMGY clear....
07megacab
Thanks for the advice. I'm still trying to decide ET vs flatbed. Flatbed would be handy for other yard projects and around the house!
Yes, a flatbed can carry unusual sizes of equipment, like a bushhog or large mower deck, will be more versatile.
You might consider building a large pod with a rear ramp door, you could finish it off like a toy hauler. You could put the pod on having the benefits of an ET, take it off for a flatbed. The pod could still store stuff, like camping gear when it's off the trailer. Put it on skids and bolt it on and off, use a small winch to pull it off and on.
billiebob
There are a few threads from guys who started building their overland trailer with a retail cargo trailer, For hauling bikes the security of keeping them out of sight is the best feature. A good cargo trailer with a welded steel frame and aluminium skin will last forever. My work trailer is 12 years old with 100K miles on it. It follows my Jeep everywhere.
billiebob
So the need is to haul one motorcycle plus an RTT.
How about a dropped frame, maybe Timbren suspension, rail up the middle as low as possible to carry the bike. RTT over obviously. Fold out kitchen on one side. Shower, dressing, etc on the other side. Bike garage in between. Think boat trailer.... maybe start with a tiny boat trailer.
No need to consider tongue weight... the bike straddles the axle. BEST possible ride for the bike too. With or without the bike the trailer will ride the same. Make the bike rail tilt to load/unload... no need for a ramp. Just put the pivot in the right place. Loading the bike backwards keeps the handlebars at the rear, maximizing the side storage pods. And holding the handlebars while pushing it on to load it keeps you outside on the ground controlling the steering.
Timbren
Supporting Sponsor
@billiebob, we're digging what you're thinking here. If you use an Axle-Less suspension with a 4" drop that would definitely keep your overall deck height lower and give you some extra clearance for your bike underneath the rtt. Definitely want to see some pics of this as you progress!
donaldsonmp3
