45Kevin
I'd really like to get some storage at the back of the van.
I'm not sure that a rack/box mounted directly on the door could support two 20 liter cans as well as a chainsaw over washboard and bumpy off road tracks. I might have a max load of 100 lbs or so.
I don't think I need a $2000 aftermarket bumper and I've been racking my brain trying to come up with a suitable mount for a swing out rack. As you owners know the way the doors open means that a pivot point for a swing out rack needs to be outside the body on the side of the van.
I have a class 3 hitch on my van and I thought that might make a good mounting point for a bracket to put on a spindle for a swing out rack.
It would be a short piece of 3x3 square tube inserted into the hitch and fastened with bolts, then a couple of pieces of 2x2 or 1x2 tube to form the spindle support. It would be fastened to the front mounting point of the hitch as well using existing hitch bolts. The spindle would be welded to the end of the bracket and a tube hoop with a shelf for the load would bend around the corner of the van and be secured to a clip of some sort on the bumper in the closed position.
Take a look at the picks and let me know what you think.
