Extreme Outback Compressor High output located in So California
I have a couple extreme outback High output 24v compressors for sale. These can be used as a 12v unit if you have a step up converter.
These are pretty much new just new old stock.
Asking $325 each per single compressor
I have also a dual set up if you want for $650 this includes everything you need. Including Cole-hersee switch, thermal fuses, air distribution block and wiring.
This is a similar kit.
The ExtremeAire High Output 24 Volt Compressor is setting the standards for high capacity compressors. By utilizing a 3/4 horsepower fan cooled motor, overheating is a thing of the past. Designed to fill the largest 4WD tires or the highest-pressure RV tires, this unit can fill tires continuously with no fear of motor burnout. With a 150psi continuous duty working pressure (200 psi max), you can fill air tanks and run impact guns to dismount and mount wheels easily. For clean air in the dirtiest environments
The dual will fill a 37/13.5r17 from 0 to 35 in about 3 min 15 seconds.
The single in about 6 mins.
Breezy78
