F-550/ Okanagan 117DBL Build Thread
n0arp
I had an Arctic Fox 1140WB a few years ago, that I had on a stock 2019 Ram 3500, then a flatbed, then a 5500. I ended up selling that and buying a 2000 Country Coach Magna motorhome. I've posted about both here, but the Magna especially isn't really in the scope of what people are here for. I have a new project, a budget truck camper build based on a used 2015 F-550 and 2007 Okanagan 117DBL. First, photos of the Arctic Fox and the Country Coach...
I learned a lot through trial and error and am building this rig a little differently. The 2015 F-550 I found has 154K on it and a Knapheide flatbed. It's a base model with vinyl seats and extended cab. I chose the extended cab for the shorter overall length and easier access to the rear without a B pillar between the doors, and 4.88 gears because I plan on going to 37s. That'll give me an effective 4.17 final drive.
First thing I did was grab a cheap Android auto head unit with wireless Carplay and swap it in. I didn't grab a photo but it was a massive improvement for $130 and integrates extremely well - steering wheel controls work, audio/nav obviously does, and even things like door open alerts. I removed the rear seats, which will be replaced with two large shelves. The bottom shelf will be for dogs to ride on, and the top shelf for my cats in crates. I'll be building those this weekend and wrapping them in speaker box carpet so they don't look too homebrew.
The truck came with a factory bumper and what I think is a snow plow attachment. I removed all that and put a cheap Hooke Off Road bumper and X-Bull 13K winch on. I had to cut off the tow hooks because they're integrated to the frame horns on the F-550 and separate the winch controller because it wouldn't clear.
I found the camper six hours across the state, and left out at 8am one morning to pick it up. It was pouring rain all day, and then I had to prep the truck-bed on-site to fit the camper on. It was raining the entire time there, and the entire way back. It was a very long day... got back after ten. I didn't check it out too much, because I got it for a steal. Unless it had major rot, I wasn't going to walk away at that price point.
I wanted to get the entire thing on the truck, so I trimmed the side fascia at the rear and cut off the septic pipe. It doesn't have an on-board generator or air conditioning, which is fine for my purposes. I bolted 8' lengths of 2x2 angle 51" apart on the bed as rails, put 3/4" stall mat between them, and sat the camper on top. I used HappiJac tie downs that I just cut to size.
Since the door threshold will be 60" off the ground once I have the new tires, I picked of Torklift Glowstep Stow'N'Go 6 steps with an add-a-step. I also have a MORryde Safe-T-Rail on the way to mount next to the door. I ordered the extended All-Terrain Landing Gear and the SafeSteps to make entry easier for our dogs, but those haven't arrived yet.
My wife wanted to break up all the brown inside. I picked up some Kilz oil-based primer and she picked out Glidden "Mesa White". Panted the walls yesterday...
n0arp
Hit the single post attachment limit. Here are a couple more photos. I'll be building a custom console/ laundry center, and mounting a floor-mount mini-split IDU on the rear slide instead of putting the factory sofa back in.
The Tru-Dually wheels with Continental 275/80R20 MPT91s came in while I was writing this. So I just threw them on... I'll have to do some trimming behind the front tires, and use FORScan to adjust the tire size. Otherwise they work as-is.
n0arp
As I said, this one is a budget build. No Victron, SimpliPhi, Truma, Cinderella stuff like my last few rigs. These are the larger items ordered for the build. I'll give a general review/comparison as I receive and install them...
4x 36x18x18" Vigorighter boxes (72" runs above deck) (I've always used Buyer's... these are clones)
4x 30x18x18" Vigorighter boxes (60" runs below deck)
1x Double jerry can holder (above deck, forward of boxes) w/ cans
4x Mission MSI10-550HT4T 550W solar panels
1x LiTime 48V 3500W 120V inverter/charger
1x PowMr 48V 6200W 240V inverter/charger (same OE as LiTime)
2x LiTime 48V 100AH RS485 LiFePO4 batteries
1x Victron Orion-Tr 48/12-20 DC-DC converter
1x EcoWorthy 12V 100AH LiFePO4 battery
1x Nature's Head composting toilet
1x Haier HA10TG21SS 9.8cf refrigerator
1x RecPro 1.0cf Microwave/ Convection/ Air Fryer Combo
1x Noxton 240V double induction cooktop
1x Hillhub Pro tankless water heater
1x Rheem ROSH15AFFJ 15K 240V ODU
1x Rheem RIFH15AVFJ 15K 240V IDU
1x Pulsar PGD40ISCO 4kW inverter generator
1x Extended run kit w/ 6gal marine fuel tank
1x Sani-Con Turbo 500S
... lots of misc electrical and plumbing parts...
... aluminum framing for the roof rack...
So I'll have 2200W solar on the roof, 1600W ground deploy (existing Renogy 400W panels I have), a 10240Wh 48V house bank, and a 4kW inverter generator with a 6 gal extended run tank. The 240V inverter should be in search/idle unless the A/C or stove is running and keeps cooktop/AC loads off the primary inverter. We'll be replacing all the appliances except for the furnace. With no roof AC, the roof rack will be kept just high enough to open the Fantastic fans (7" high).
n0arp
Delam on the cabover inspected and stopped. Preemptively did the same on the driver's side of the cabover, and bottom edge of the back wall. I didn't really see any delam when we bought it, but did note the seam at the bottom of this wall wasn't sealed, and it did start delaminating on the way home which was a six hour drive in the rain. Dried it out and made sure it wasn't moldy or rotten before sealing it up and clamping it down. Photos pick up shadows and differences where I touched and/or cleaned it, so look a bit worse than it does in person. It's a lot less obvious to my eyes than through a camera, and I'm hoping that once I clean up the entire camper that'll translate to photos as well.
n0arp
Full reseal and added a MORryde Safe-T-Rail for the steps since they're so high off the ground. Also mounted the truck boxes They seem slightly thinner than my real Buyer's boxes -- maybe 16ga instead of 14ga, though I didn't measure -- but are plenty stout.
n0arp
Mounted up the 15K ODU yesterday. Used the same off-the-shelf Turbo mount that has served me well on the motorhome, but trimmed down the legs a bit. Tried to make it as close to the camper as possible, while still allowing room to breathe, and ended up with it sticking out about the same as the ladder.
Still fairly upset about the delam, but it's stopped/dried out and won't be getting any worse. All the trim is on, but I'm going to have to get a heat gun and work over the top corners of the door which were fine yesterday, but peeled off by the time I went for photos this morning.
The mini-split bolts through the wall (six 1/2-13 bolts with fender washers and nylocks), through double 3/4" plywood, that is part of a cabinet. The cabinet has a false bottom that will hide the plumbing and line set, and above that, a litter box area for the cats (a porthole will be cut into it) and storage. It has a butcher block top that will be ripped down the length and piano hinge installed, for access. On the left side, a washer/dryer combo will sit. The carpeted step-up hides the slide bolts and provides a hard stop to keep the W/D from sliding forward, at exactly 25"D. The gapped rear corner is where the drain connection will go.
V45W_Proto2.5
