F/S: 2005 BMW R1200GS - Parting out
richardas
Manufactured July 2004. 27K miles.
If you want something that I haven't listed, send me a PM. Check the bottom of this post for parts already sold.
I'll take Cash, USPS Money Order, Cashiers Check or Paypal.
Links to larger pics;
https://picasaweb.google.com/lh/photo/D_ipRNiTGzurU7si52nL7g?feat=directlink
https://picasaweb.google.com/lh/photo/Wy6iXCEwkfxPb5cdaNXRZA?feat=directlink
Parts Available:
- Bash Plate, $30
- BMS-K Control Unit, $250
- Brake Caliper, Front Left, $125
- Brake Caliper, Front Right, $125
- Brake Caliper, Rear, $$125
- Brake Pedal, $30
- Clutch, $200
- Cylinder Head - Left w/valves, etc, $300
- Final Drive, $550
- Footpeg - Left, $10
- Footpeg - Right, $10
- Fork Trailing Arm, $100
- Frame, Rear, $200
- Fuel Tank, $100
- Fuel Filler Cap, $35
- Generator, $230
- Handlebar, $70
- Ignition Coil - Angled Left, $30
- Ignition Coil - Angled Right, $30
- Injector, $30
- Lever, Handbrake w/reservoir, $80
- Luggage Grid, $50 with mounting bollts
- Oil Cooling Pipe - Inlet, $20
- Oil Cooling Pipe - Outlet, $20
- Shock - Rear, $190
- Shock - Front, $150
- Side Stand, $35
- Starter, $135
- Throttle Housing - Left, $100
- Throttle Housing - Right, $85
- Transmission, $600 - Renewed fluid @ 25k miles with Royal Purple synthetic 75/140
- Wheel Cover, Rear, $15
- Wheel Speed Sensor, Front, $25
Parts not available:
ABS Modulator
Alarm Unit w/transmitter
Brake Pads
Brake Rotors
Center Stand
Combo Switch, Left & Right
Drive Shaft
Exhaust, Header & Can
Fairing Bracket
Fenders
Fork Legs
Frame, Front, $100
Grips, Heated
Headlight Assy
Ignition Coils, Primary
Instrument Cluster, $260
Lever, Clutch w/reservoir
License Plate Bracket, w/reflectors
Mirrors
Oil Cooler
Rims, Cast, includes ABS ring & Shinko Trail Master E-705 w/2k miles.
Seats
Side Panels, Aluminum
Side Panels, Black w/BMW Roundels
Strut for Final Drive
Swing Arm
Tail Light Assy
Tank Panel
Top Case w/mounting Bracket
Turn Signals
Valve Covers
Valve Cover Guards, Plastic
Vario Cases w/mounts
Wind Shield
Wire Harness
TNielson-18
