I agree, get the Bilstein 5100 series shocks that lift the front 2" if you're only leveling the truck out. The angles of the axleshafts and control arms are reasonable at 2", and the shocks limit the travel to prevent any binding or over-extension. The down side (to any leveling kit) is that you lose droop/downtravel from ride height, but the ride is still good over all.
I am running the 5100s at 2", with a 3" rear block replacing the factory piece. Wheels are stock, tires are 35x12.50R18 BFG KM2s, no rubbing. The clearance between the front tires and upper ball joint is very small, many (most?) 35s would contact there, depending on the sidewall lugs. Eventually I will be lifting the truck, probably with the superlift 4.5" lift to get the proper suspension travel back.
I also re-geared to 4.56 gears and locked the front and rear. The 3.73s were tolerable on flat land but definitely not ideal off road, towing or in the mountains.
