Feniex Industries 4200 Mini Controller
chet6.7
I read that this unit can only handle 3.2 amps per switch, so my question is, if using a relay to connect to a pair of Hella 4000 100W lights will the capacity of the 4200 controller be exceeded?
Thanks.
ExpoMike
Relays typically only use less than a .25 amp, so if you are using relays to switch the high current load, the controller will have no problem handling switching the relays.
Jacobm
I believe this is a rebranded Auxbeam/same manufacturer, but from a vendor with actual customer support: https://www.strobesnmore.com/touch-6.html
It's not quite as polished as the 4200 Mini but it includes relays that handle a lot more amperage. I've been looking at those two products for my own electrical projects but I haven't purchased or used either so I can't comment on quality. The 30 Amp circuit should be fine to handle a pair of 100W lights though.
Mcoleman
