Fg649 After Market Vee Belts
gait
Replace vee belts with Mitsubishi parts I've been carrying around for 5 years.
I have old belts labeled 12.5x1185 (two for alternator drive) and 12.5x1450 for aircon.
"Standard" vee belt profiles include "A" 13mm wide by 8mm deep.
what size vee belts do I need?
PS I'm guessing Gates V Belt 13A1175 and 13A1450
for some reason 13A1180 is $5 extra.
Most A section belts are 11mm, 13mm or15mm wide now. then the figure after that is the length of the belt.
With the amount of adjustment these motors have you could use 13A1170,13A1175 , 13A1180 or 13A1185 But try and get a matched pair.
Air con belt 13A1450 will be fine.
Gates green stripe are a heavier belt if you can get them.
jgwarren319
