Finally have a way to remove the camper!
tanglefoot
ExPoseur
This poor trucklet had been lugging this camper around since I found it about 5 years ago, but I finally figured out a way to take it off!
This camper was, let's just say, significantly under $1k, so I couldn't justify buying jacks, and the ones on Craigslist seemed to keep getting snatched up.
So, I started collecting some pieces of chain, angle-iron, a pair of cheap chain hoists and hardware bits and went to work in the outbuilding. A three-foot length of angle-iron was bolted under each side-shelf of the camper. I did my best to guess the balance point but ended up moving the holes around a little bit. Four grade-8 bolts connect the short chains to the angle iron "brackets" and the chain hoists hook onto those. I figured the hoist closest to the exterior wall would have enough support but I added a vertical support (sandwiched 2x8s) just past the second chain hoist.
It felt a little precarious once the truck came out from under the swinging camper, but it seemed to balance alright. There were bolts through the short chains on either side of the hoist hooks to prevent the chains from sliding through the hooks and standing the camper on end :Wow1:
Ain't she purty? (Next time, spray-foam will not be used!)
Then, one side at a time, it lowered right down onto some 2x4s on the slab (try that with your camper jacks!) and my blood pressure came down with it.
The 4runner looks like it wants to jump around like a grasshopper now. I can't wait to drive it. It'll take some tinkering to put things back (like the tailgate strikers), clean it up, and stretch the soft top over it, but I imagine it'll be quite a bit more nimble and spirited again. :wings:
austintaco
It will definitely feel zippy. Now that you can see where you had the foam, it can help make a proper seal and just follow the shape left by the foam. Either way, great truck.
Taylor1
Swinging things from the ceiling is the best. Any idea the weight of camper compared to the factory top?
Sent from my LG-D800 using Tapatalk
tanglefoot
ExPoseur
My guess is that the camper is about 700 lbs.
The original fiberglass top is about ~100 lbs, I think.
The Kayline soft top is ~ 20 lbs w/hardware.
subterran
Oh no! Are you going to revert back to tent camping? I hope you arent going to abandon us - I was so proud of your old-skool toyota 4 banger hauling around a pop-up Taj-Mahaul! (I'm hoping you're getting a new truck)
LuckyDan
Me too. I personally have found your posts, especially the low buck approaches to some high buck problems both entertaining and informative.
tanglefoot
ExPoseur
Oh, thanks guys!
I drove the trucklet around without the camper today. Even with the little flatbed trailer hitched on, it felt like a sports car in comparison to when the camper was on it. I had a blast! There's something to be said for running light.
I imagine I'll use the camper again--I may just be taking a break. There won't be a new truck, but I may try putting the camper on the flatbed trailer next year, since I love how the truck drives without it on the back. I may also do some car camping next year, maybe with the hatchback. We'll see. I really don't camp that often...maybe a half-dozen nights/year.
Houie
