For Sale | 1997 Lexus LX450/ Land Cruiser FJ80 | $20,000
matertat
Matt & Rach
I bought this truck in 2019 from Florida (The frame is so clean you can eat off it!) with the goal of turning it into an overland vehicle. It is now in Orange County New York. It is running like new. Maintains oil level, and drives and shifts beautifully. It has been an awesome rig, and it was going to be long term ownership (why I have done so much mechanical work) but something came up in our family, and unfortunately, I need to sell it. Right now there is 220k miles, but this is a daily driver, so they will be accumulating slowly. Only serious inquiries please.
Here is a walk around video:
Below you will see all the work that I have done to the truck (not including oil changes every 3000 miles).
• Removed plastic body panels and repaired body
• Factory color paint and clearcoat on the entire vehicle
• Escape Gear seat covers (front, bench and dash cover)
• Sony XAV-AX5000 double-din radio with CarPlay
• Old Man Emu 2.5” Suspension lift
• 305/70/R17 Mud Terrain tires
• Custom drawer system installed in trunk (removable/anchored with turnbuckles)
o 3 drawers, one with table surface​
o Hinged panel that lays on top of reclined seats​
• After market MaxTrax mounted on Thule roof rails.
• ARB 2000x2500 (6.5’x8’) awning
• Pelican Vault V700 rifle case mounted on roof
12/12/2019 / 210,000mi
Services Performed
• Four tires replaced (305/70/R17)
• Old Man Emu 2.5” Lift kit installed
11/19/2020 / 210,000mi
Services Performed
• Battery cable terminal end(s) replaced
• Battery replaced
• Battery tray/cover/hold-down replaced
• Mirror replaced
12/22/2020
• Registration issued or renewed
• Titled or registered as personal vehicle
• Passed safety inspection
03/20/2021 / 215,500mi
• Undercoating/rustproofing applied
03/25/2021 / 215,587mi
07/03/2021 / 216,000mi
• Body work and paint job
08/12/2021 / 216,100mi
• Antifreeze/coolant flushed/changed
• Heater control valve replaced
• Heater hose(s) replaced
• Thermostat replaced
11/06/2021 / 217,820mi
• Differential fluid flushed/changed
• Oil and filter changed
• Transfer case fluid flushed/changed
02/23/2022 / 219,856mi
• Air filter replaced
• Brake fluid flushed/changed
• Distributor cap replaced
• Distributor rotor replaced
• Fuel filter replaced
• PCV valve replaced
• Power steering fluid flushed/changed
• Rear brake caliper(s) replaced
• Spark plug wires replaced
• Spark plug(s) replaced
• Tires rotated
• Valve cover gasket(s) replaced
02/24/2022 / 219,856mi
matertat
Matt & Rach
Thanks Dale. I am going to be sad to see it go.
It is over there as well!
Chonker LMTV
