Rube2K6
2011 Adventure Trailers - Chaser
- White powder coat with black fenders
- Steel powder coated nose box
- Independent trailing arm suspension with air struts
- Six-foot cargo box provides 46 cubic feet of storage
- Cargo box has gas strut assisted lift cylinders
- Locking tail gate- 16" x 32"
- Rubber matting on bottom and sides in cargo box
- Cargo tie downs inside cargo box
- Drop leg tongue jack
- 2" rear accessory receiver
- 2” Multi-axis coupler
- Electric brake axle
- Wayne's RV Stabilizer
- Thule Rack load bars on adjustable track
- Eezi-Awn Series 3, 1800 rooftop tent
- Eezi-Awn 2.0 awning
- 3 Eezi-Awn Series 2000 Rec-Vee panels and floor (pic not mine, copied from the web)
- Two 5 gallon fuel cans with AT holders
- 19 gallon water tank with hand pump
- Utility shelf - shaped and finished hardwood plywood
- LED Rectangular Floodlight- rear of trailer
- Interior LED nightlights with dimmer switch
- Odyssey AGM group 31 battery with aluminum hold-down bracket
- NOCO Genius 10 amp onboard battery charger with shore plug
- Sun Guard solar controller
- Plug-in connector for solar panel
- Volt meter
- Auxiliary 12v outlet on tongue box
- 12v outlets inside cargo box
- Locking tailgate option
- 5 lb. propane tank with aluminum mounting bracket
- 35” BF Goodrich KM2 Mud Terrain tires
- 5 on 4 1/2 Jeep TJ wheels
- Canvas trailer cover
- No trail rash. Has never been on its side or top.
- Second owner. I purchased it in January 2014. Just don’t use it often enough.
- Located in Fallbrook, CA
- More pics available if needed
