This combo was thoughtfully built for each other. The goal was a fully kitted slide in camper with as small a profile as possible. That’s why I put a Fleet (normally built for Tacomas) on a Tundra. It rests on a 4” platform that allows for extra storage on the sides of the camper and possibly underneath. The truck is built to get anywhere you can dream of. Highlights include 5.29 gears, full armor and recovery, beefed up suspension, and updated interior.
2018 Tundra SR5 Double Cab w 62k miles
All maintenance has been done on schedule and there have been no issues or accidents. This truck will easily run to 250k miles, unlike the current generation of Toyotas. The truck is immaculate inside and out and has been stored inside. Factory added options:
- Toyota bedliner
- SR5 off-road 4x4
- Toyota safety sense with automatic cruise control.
- 5.7L V8 Engine
Added aftermarket
- Dobinsons 2.25” HD lift with shocks and springs. This easily carries a four wheel camper.
- Icon thrust wheels with 35x12.5R17 e-rated duratracs. Full sized spare.
- Firestone ride-rite air bags w/ Daystar cradles.
- ADD Stealthfighter Bumper w/ sensors.
- Warn VR Evo 12.5K Winch w/ synthetic line and Factor 55 Flat link shackle.
- Rigid 40" Curved Lightbar.
- TRD Pro Grille w/ TSS Relocation Kit.
- CBI Overland Rock Sliders
- RCI Aluminum Engine and Transfer case skid plates.
- Dirty Deeds custom exhaust.
- Nitro 5.29 Gears
- ARB Rear e-locker
- ARB Twin Compressor under the hood with an air hose outlet under the rear bumper.
- Switch Pros SP9100 with SDHQ mounting kit.
- AGM Battery
- Baja Designs S2 Ditch Lights
- Kenwood 7" Head Unit with wireless carplay. Sirius antenna relocated. Removing the horrible factory radios opens up a much better sound for the stereo.
- TRD Pro Shift knob
- Blacked out interior and exterior trim.
- Katzkin black leather seats with seat warmers installed in the front seats.
- Wireless charger in center arm rest.
- Husky X-Act floor mats.
- Brand new Frozen Rotors cryogenic frozen slotted brake rotors w/ Hawk green pads.
- Color matched side mirror caps.
- Ceramic tinted windows all around.
- Glind heat exchanger shower system.
- Upgraded LED interior lights.
- DCDC alterntor charging wired with 6awg wire and an anderson plug in the bed.
Title is in hand.
2015 Fleet Front Dinette Four Wheel Camper with Lithium Conversion
2nd Owner, purchased in 2020. Camper has many thoughtful upgrades, including full Lithium conversion with all new Victron components wires and fuses. Lithium conversion alone costs around $6000-$10000 to have it done for you.
Factory Options
- Front Dinette
- King Pull Out Bed
- Flush mount Dometic Sink and Stove
- Rear Awning (rare feature)
- Propane Heater with 2 propane tanks
- Thermal Pack
- 4 reico jacks.
- 80L 12v/120v Dometic Fridge/Freezer
- 20 Gallon Fresh Water Tank
Interior Upgrades
- Custom 4” Bed mattress made by Bountiful Rest Mattress in SLC. Includes washable covers. Extremely comfortable compared to original FWC mattress. Original mattress is also available.
- Hypervent base under mattress that provides extra cushion and prevents condensation under the mattress.
- All electrical components have been. upgraded. Custom 280ah Lithium battery with battery heater. Includes a JK BMS and the heater is turned on via rocker switch. All electrical lines are properly sized up, organized, and proper sized fuses and breakers have been added.
- Victron Smart Shunt controls the battery and systems. You connect through Victron app to get battery details through your phone. There is not an exterior monitor screen.
- Two new 100w solar panels with a Victron 100/30 MPPT Solar controller. Big controller enough if you want to add additional panels or use the exterior port for a mobile panel. Connects via Bluetooth to Victron smart system.
- Victron IP22 30amp Smart Charger for specifically charging Lithium batteries via shore power. Connects via Bluetooth to Victron smart system.
- Victron 30amp Orion DC to DC charger with upgraded 6awg wire for DC to DC charging. FWC uses 10awg standard and this is undersized and causes poor DC to DC charging due to length of wire and voltage drop. The connector is changed out to a more robust Anderson connector. Connects via Bluetooth to Victron smart system.
- New CO2/propane detector that doesn’t randomly go off like the original.
- 2 Additional 12V outlets added behind couch cushion for included WeBoost and additional charging.
- Flush mount water pump switch relocated to below sink for easier access.
- Water tank gauge replaced by BlueSea digital gauge that gives more accurate water levels in 5% increments vs 25% increments on standard.
- 1200w Pure Sine wave inverter with added 110v outlet. Located below dinette seat.
- Maxxair 4500 10speed MaxxFan with remote. Replaces loud 3 speed fan.
- Reflextix window covers for all windows. Adds insulation and light abatement. Original drapes are also included.
Exterior Upgrades:
- Mule awning brackets with ARB awning.
- Zero Declination privacy/shower tent.
- 80/20 mounts on rear. We used them to hold trash bags and other containers. Extendable WeBoost antenna attached and included. Joolca hot water shower could easily mount here.
- Frontrunner roof rack with 2 crossbeams. You can fit 2 paddle boards on the roof and with solar configuration, you can put one on the roof and still capture full solar energy. Additional Frontrunner accessories can be added for additional cost.
- Mule Jack Extensions
- New 40lb struts that make lifting of roof easy, even with paddle boards on top.
The camper has been thoroughly cleaned inside and out and is in great condition. All exterior plastics and canvas has been regularly cleaned with 303 aerospace cleaner.
Pots, pans, plates, dishes, cookware, and utensils can be included for additional cost if you want this turnkey ready.
Willing to seperate camper and truck. Camper $25K, Truck $50k. Located in Sisters/Bend, OR
- Toyota bedliner
- SR5 off-road 4x4
- 5.7L V8 Engine
Added aftermarket
- Nitro 5.29 Gears
- ARB Rear e-locker
- AGM Battery
Title is in hand.
Factory Options
- Front Dinette
- King Pull Out Bed
- Thermal Pack
- 4 reico jacks.
Interior Upgrades
Exterior Upgrades:
