JUST TRADED IN
Call or Text: 801-860-0035
Meet Woolly Bear Overland.
More than just a gear hauler, Woolly Bear is the utilitarian basecamp you’ve always dreamed of. Features include a full-size outdoor kitchen, storage systems, pull-out cooler drawer, and an elevated platform that accommodates most 2- to 3-person tents. It’s packed full of as much innovation as it is trail-ready gear.
- Includes one set of risers + spare wheel and tire.
- Nomadic 3 Extended Roof Top Tent ($1,549.99)
- TUFF STUFF 270º DEGREE COMPACT AWNING ($749.99)
- One 5lb Propane Tank
- 40 watt Solar Panel with Trickle Charger
- 7a Solar Charger
- 90ah AGM Battery
- Anderson Plug for DC/Dc to Charging (no dc/dc charger included)
NOTE: Not Included Fridge or Cooler as its placed for imaging purposes. Wheel Chucks NOT included
Woolly Bear Specs*
Exterior Width | 5'4" |
Exterior Length | 10'8" |
Dry Weight (including standard features only) | 1,270 lbs |
Tires | 235/75R15 |
Ground Clearance | 12" |
Tongue Weight (depends on load) | 140 lbs |
Tongue Height | 21" |
GVWR | 2,100 lbs |
Capacity | 3 Adults in RTT |
Cargo Capacity | 830 lbs |
Exterior Height (top of cargo deck) | 4'9" |
Exterior Height (top of highest riser setting) | 6'5" |
Exterior Height (top of highest riser setting + roof tent) | 7'3" |
Cargo Deck Dimensions | 91.7” x 33.25” |
Top Left Cabinet | 12" x 3.75" x 13" |
Bottom Left Cabinet | 12" x 9" x 13" |
Middle Cabinet | 9.5" x 13.25" x 13" |
Top Right Cabinet | 25" x 3.75" x 9" |
Middle Right Cabinet | 25" x 4" x 15" |
Bottom Right Cabinet | 25" x 4.5" x 13" |
Under Galley | 51.5"L x 16"W x 15"H |
Cooler Drawer Storage | 31.5"D x 18.5"W x 18.75"H Drivers Side |
Main Storage | 51.5"L x 16"W x 30"H |
Wet Storage Bay | 32" x 15" |
Cargo Deck | 91" x 32" |
