For Sale: Snow Peak Single Action Large Table
spressomon
Selling my Snow Peak Single Action Large Table. This table has a custom fabricated top made from composite panels purchased from AT Trailers (same material they use in their drawer units). Additionally the table top, bottom and side edges have been covered in a dark granite color Formica laminate. The leg hardware is bolted to the composite panels via "T" style nut inserts installed prior to the Formica resulting in a super solid platform for the leg assembly.
This table is approximately 30% lighter (20lbs versus 28lbs) than the bamboo plywood topped original version! In addition to being significantly lighter in weight the table, including the top, is impervious to moisture (shortcoming of the OE bamboo plywood top from Snow Peak).
The table can be set-up or taken down in all of about 5-seconds! And includes the Snow Peak nylon cover with carry handles. Aluminum legs, composite top and all stainless steel hardware.
Dimensions:
Set-up: 26" tall x 48" long x 28-1/4" wide
Folded: 14" wide x 48" long x 3-1/2" thick
$175
spressomon
The composite board, while not perfectly flat, is considerably 'flatter" than the bamboo plywood it came with...
Its probably a mm or two out side to side...if you're entertaining royalty with fine china, silverware & Riedel stemware then maybe it would be an issue :D. Anything camping/picnicking related it hasn't been an issue.
RVAHomePRO
Still Available?
Wondering if your table is still available. Any clue what shipping to 23005 would be?
spressomon
The sale is taking a recess for a few weeks as we are in the process of moving and the table is in storage. But given its size and weight I'd be surprised if a box and shipping would be less than $50 FedEx Ground/Home...just a guess based upon recent shipments of other heavy/bulky goods.
TNielson-18
