Ford 10.5 E-Locker & Rear End Parts — Sterling 10.5 — 2012
WinnieVan
Have a complete rear axle from a 2012 f250. The housing is bent but the other parts are fine.
Have a sterling 10.5–housing is bent but other parts are good.
specs
- 4.30 gears with e-locker ($400) ring pinion and carrier complete
- rear brakes (complete) and axle brackets ($100)
- rear hub units with bearings ($200)
- rear axles ($50 for the pair)
located in Salem OR
97301
Will ship on your dime!
Huge preference to someone who wants the whole axle — will make a good deal if you can pickup.
Curious how it got bent? And how you figured out it was bent, assuming it's not visually obvious.
Sent from my SM-G973U using Tapatalk
As for how — came from a salvage yard and the truck was rear ended so I presume it happened when the truck was rear ended. I asked the guys to make sure it wasn’t bent — and they did — I only found out after I swapped it into my e-series and went for an alignment…
was gonna get the housing straightened but no one near me was setup to do it.
stand up yard too… they gave me money back at least.
jgwarren319
