Up for sale complete Dana 60 front from a 2003 F250, brand new fuel tank, manual transfer case and Miscellaneous 4R100 transmission parts. I have a ton of new parts for the full overhaul of the axle
Were planning a Ujoint offroad conversion that I don't have time with.
Price $2500
Axle
FORD Model 60/248 FRONT 2002 - 2003 F-250/350 SRW (4X4)
Bill of Material 611337-1
Diff. Type STD
Ratio 3.73
Transfer case
NV 271 manual tranfer case with the Transmission crossmember and shaft and some
other parts for the 4R100 transmission.
Extra fuel tank for the 7.3 Powerstroke if you want to shorten the tank and have it ready to swap later
New unboxed Parts for rebuild the Axle
41784-2 Spicer Ford Super Duty Dana 50 / 60 Yellow O-ring Vacuum Hub '99-'04
41784-2 X2
47766 Dana 50 60 Thrust Washer
47766 X2
50381 Spicer Dana 50 60 Outer Axle Spindle Seal
50381 X2
701166X Dana 50 60 Thrust Washer Kit
701166X X2
710494 Dana 60 Outer Vacuum Hub Seal W/ Slinger
710494 X2
Spicer 708233-2 Dana Super 60 Front 4.10 Reverse Ring & Pinion Gear Set
708233-2 1
Warn 38826 Dana 60 Premium Manual Locking Hubs 30 Spline GM/Chevy Ford Dodge
38826 X1
YAD76151-2X Yukon 1541H Inner Axle For Dana 60 '00 And Newer F350 Superduty
YAD76151-2X X1
Yukon YMSS1018 Dana 50 60 Ford Front Axle Guide Tube Seal Replaces 52148
YMSS1018 X2
CARLSON 41196 Caliper Repair Kit X2
CENTRIC 14554002 (145.54002) Caliper Piston X4
CENTRIC 14365017 (143.65017) Caliper Repair Kit X2
MEVOTECH MK80072 Stabilizer Bar Bushing X1
MOOG 515056 Wheel Bearing & Hub Assembly X2
MOOG K80026 Ball Joint $ 26.89 $ 0.00 X2
MOOG K8607T Ball Joint $ 40.79 $ 0.00 X2
X2 MOOG/PRECISION 374 Universal Joint X2
Not looking to sell anything separately so don’t bother asking all or nothing it’s a good price for your van build.
$2500
Price $2500
Axle
Diff. Type STD
Ratio 3.73
Transfer case
41784-2 X2
47766 X2
50381 X2
701166X X2
710494 X2
708233-2 1
38826 X1
YAD76151-2X X1
YMSS1018 X2
$2500
