Ford F550 Camper, Race Support Truck, Work Truck - $48000 (REDDING)
Jjackson410
Not mine but something i found on Craigslist..
https://sacramento.craigslist.org/rvs/d/ford-f550-camper-race-support/6385475160.html
2008 Ford F550 W/Camper
condition: excellent
cylinders: 10 cylinders
drive: rwd
fuel: gas
odometer: 22000
paint color: white
size / dimensions: Box 20' at roof
title status: clean
transmission: automatic
2008 Ford Super Duty F550 with Custom Built Marathon Camper
Pulling a Race Car, ATVS, Horses, Need a fantastic Bug Out Truck/Camper for your Family? This is a ONE OF A Kind Custom Vehicle
IF YOU HAVE DOGS, HORSES, BIKES, RACE CARS, NEED A SERVICE VEHICLE OR JUST WANT THE TOUGHEST, MOST STEALTHY CAMPER YOU CAN GET....READ THIS!
Power
HDw/v10 and HD 19,500 GVW, commercial towing package to 18,000 lb., and Allison Transmission. Every cooling Package avaliable has been installed for reliable All-climate operation.
After one trip to Canada my new trailer smelled like **** literally. Between the cooking, the dogs, and everything else my brand new trailer was a mess. And really there is no way to clean it, just cover it up. So.... I built this.
Made originally from a commercial vehicle the camper has earned it's Motor Home status by the DMV. This entitles you to the cheapest insurance available saving over $1,000/year. This is no over designed luxury unit that you will have to have repaired by a Motorhome Tech at $100/hr. This camper can be washed out with a hose. Every cable, wire, tank, outlet, pump, drain, hose, and appliance is removable and repairable without any trouble, in less than five minutes. You can literally see every connection so you will know immediately if something is wrong. The interior surfaces are waterproofed, diamond plate aluminum, 12 gauge stainless steel, and 3/4" furniture grade plywood. The shower is coated with 3,700 lb. impact Bridge Paint which is indestructible by impact, mildew, or harsh chemicals. The door to the bathroom is absolutely private and waterproof. The sink is commercial quality, the hot water unlimited On-Demand, the water pressure good. The generator can be operated on-board and is completely separated and silenced. It can be rolled out of the camper and used outside, remotely, or you can utilize the Remote Power Box to operate appliances or tools. The windows are all whether double pain ready for rain. There are side ports for a high efficiency two tube portable air/heater or a place for a roof unit. All shelves and drawers are suitable for heavy tools. There is a 2,500 lb. hydraulic lift that folds away under the bumper to load bikes, tool chests, or any other cargo through two full size security doors in the rear. There is a security side door with diamond plate steps and outside retractable step. There are internal racks that are infinitely configurable with Speed-Rail for storage of Kayaks or other items you don't want stolen while you are gone. The mattresses are marine grade materials and completely waterproof/stainproof. The electrical systems runs on DC from your batteries and internal charging system, AC from your generator 120/240, or AC from shore power 20,30 and 50amp. Every internal plug can be routed to any of the three sources as needed, depending where you place or need your power. Every aspect of this build was to minimize service, maximize use, safety, utility and to eliminate the typical issues that ruin motorhomes, trailers, and campers.
Features
No Diesel problems! No Stink, mixture issues, additives, noise, or high repair costs.
This gas powered V10 has more torque, more horse power and a much higher revving engine delivering better power and runs on 87 fuel. It is the most produced and utilized motor in commercial trucks, motorhomes, campers, buses etc. for the past 10 years while diesels have gone through multiple generations trying to solve their inherent problems. Due to it's expansive use, parts and service for the V10 are available at any ford dealer in the country. They are known for reliability and quiet power that doesn't stink if you need to work around it while it is running.
Milage: 22,400 with service record, only one owner.
Transmission: Allison Automatic ( it is connected to the towing system and downshifts when you brake while computer controlling your trailer brakes.)
Computer interface towing control regulator on dash
Sumo Bags: rear 12,000 lb assist, front 8,000 assist in addition to the 19,500 lb.
Rear, Side, and Inside Camper Cameras w/8" screen in the cab
Custom painted front fenders
Stainless grill package
Custom Box built by Marathon
One piece aluminum roof
Grade 37 insulation in ceiling
Box construction heavy duty fiberglass laminate throughout
Hardwood Core exterior doors w/security steel frames
HD towing package
HD cooling package
HD suspension package
HD differential cooling package
HD transmission cooling package
2 RV Batteries w/built in charger
Honda 6,500 Watt Quiet Cool Generator
(generator can be wheeled out of the truck and used externally or operated in the truck
It's compartment is fully sealed and properly vented for the operation of the generator on-board while driving or parked)
LED interior work lights
HD 18,000 lb. hitch with cab control electronics
Vinyl seats and floors
Custom Gauge package
Cruise Control
Tilt steering
Air Conditioning
Electric Windows
Hydraulic Lift Switch Cut Off
Premium Stereo
2,500 lb. hydraulic lift that tucks under truck
Custom aluminum lift gate
3 Steel lockable jockey boxes
Double rear security, double lock, doors
Ambulance side door with diamond plate steps
Diamond plate floors coved to 4 foot high on the side walls
Floor is built on 4" of hardwood and water proofed for wash-down
Box overhang is Diamond plate with polished stainless frame
D rings throughout the box for tying off equipment/toys
Speed Rail ceiling racks can be infinitely configured with speed-rail fittings
Shower/Porta potty with stainless threshold, heavy privacy door and LED lighting
On demand Hot water
Propane storage
Propane portable stove
50 gal of fresh water, 50 gal of gray water and 5 gal of drinking water
Drinking water pump and dispenser
12 Gauge stainless counters w/ a 16 gauge silenced stainless double sink.
12 Gauge stainless work counter
Fold up work table
Fold up cooking table
Closet
Additional storage
Storm/Rain windows on all sides with UV protection
2 oversize marine grade vinyl mattresses with marine grade foam.
Co2,propane, smoke alarms
Roof vent (crank open)
Blackout curtains
Refrigerator
On demand 12 volt water pump
All interior paints are marine approved and water proof
If you get this far you are asking why I am selling it. My wife and I retired and moved to paradise. We live in an oak forest by a wonderful lake and feel no need to travel anymore. We used the camper to facilitate our move to the north and it did the job through the rainiest winter and hottest summer they ever had here. Since we are not any longer using it we just can't stand to see it sit here un-utilized. Until you find your paradise this truck is for you.....
Goldenbora
