Ford Superduty F-250 4x4 Energy Suspension Master Bushing Set $150 Shipped
New in box. Black in color. Sold the truck before I could put it in.
Energy Suspension 4.18124G Complete master bushing set
Fits 1999-2004, Ford F-250 Super Duty with 4WD
Energy Suspension's polyurethane suspension bushings offer the greatest improvement in your vehicle's handling for the least cost. These "Hyper-Flex" performance bushings make your car's suspension much more effective. It's as if you installed a bigger sway bar but at a fraction of the cost. Energy's special formula "Hyper-Flex" polyurethane will last much longer than the OEM rubber components, and each kit includes corrosion resistant zinc plated 3/8" grade 5 bolts, nylon lock nuts, heavy gauge washers, and mounting brackets. Installation is easy and it's a great performance upgrade no matter what you drive.
Black
Includes front track rod bushing set, front and rear leaf spring bushings, front and rear sway bar, & end link bushings.
Energy Suspension 4.18124G Master Set
Goldenbora
