Frame-Off Restored M416 Trailer (Independent Airbag Suspension, Kitchen, RTT, etc)
dieselcruiserhead
16 Years on ExPo. Whoa!!
Hi guys,
Well it is unfortunate... I built this because "I always wanted one" and not really because I need it (though I really enjoyed this trailer and I really enjoyed building it). I can possibly deliver to most cities in the west (as I'm only 1 day's drive away) and/or possibly arrange a ride to Reno NV as well around Sept 1. Otherwise I can probably truck ship it freight at buyer's cost... No expense was spared in the build and I probably have about 200 hours I figure (6 months with regular work) in its construction.
1966 M416 1/4 Ton military trailer.
  • Frame off sandblast and restoration
  • Tongue extended 18"
  • Lid with ladder rack in frame design to secure 6 military cans (plastic or metal, fuel or water)
  • Heavy duty 3500 lb axles. No trailer brakes (but they can be added very easily - bolt on)
  • Slide out kitchen drawer, food storage, cooking surface
  • Paint is "ZeroRust" which is similar to POR-15 but better cosmetics and a rust bonding paint that is what the USMC uses for their tan drab. Very durable and good looking. Tan body, black frame and fenders, suspension, and underbody/tub.
  • ARB Simpson II Roof Top Tent mounted on Thule cross bars
  • Aluminum Rims, BFG 33 x 10.5 All Terrains
  • Built extremely tough and heavy duty. It has also been trail tested and performed flawlessly. The cross member where the arms mount is a little tweaked due to its thin metal after heavy off-roading so I am about to cut it out and put in a new crossmember with thicker steel and I will re-align with a laser.
  • Fenders widened by 2"
  • Re-use and design using the factory military turn signals, which were restored.
  • Complete frame off restoration including new wiring
  • 20 Cal Ammo Can used as electrical center box and storage. "Smart" wiring that uses a plug extension that adapts to any 7 pole plug.
  • Trailer is completely locking using its own matching key (several copies of original factory lock keys included)
  • Trailer tows perfectly and at all speeds, on or off road. The technique to towing this trailer is "pretend its not there" and it will literally "follow" you anywhere. I found it matched the track of my Toyota perfectly which made it excellent for off road.
Let me know if you have any questions. Located in Park City, Utah (20 minutes east of Salt Lake City). Asking $6500 with the ARB tent or $5200 without. Pretty firm on price. Here is the complete build thread here on the Expedition Portal.
Photos: (Edit: sorry for all the photos, I wanted to document all the modifications):
Before..
attachment.php
Sand blasted:
attachment.php
Front cross member added and tongue extended:
attachment.php
attachment.php
dieselcruiserhead
Independent Suspension, laser aligned... Again I have to replace the cross member the independent arms are attached to and will re-laser align. I figure it should take about 1 day and I'll do it later this week.
attachment.php
3500 axles, very heavy duty (no trailer brakes). You can add trailer brakes easily...
attachment.php
Mountain brackets (made by Adventure Trailers) for the Firestone airbags:
attachment.php
dieselcruiserhead
Independent A-arms and the frame: photo also shows close up of the Zero Rust paint and it's quality. It is sort of like a plastic-filled rust killing paint. It is very very solid and very durable. Both the black and tan are the same paint.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
dieselcruiserhead
Here is the tailgate, note the sliding latches into the original box:
attachment.php
Tie-downs on the tongue:
attachment.php
Receiver added to rear hitch for recovery or transport of mountain bikes, etc:
attachment.php
Here is the lid frame that secures 6 water/fuel cans (plastic or metal):
attachment.php
Ladder rack. You basically position the cans in the correct location in the trailer and it locks them in place:
attachment.php
Removable lid using large, heavy duty greaseable barrel hinges. Fake raingutters for Thule or Yakima cross bars:
showthread.php
Tie downs on the lid:
attachment.php
Before paint (and fender widening):
attachment.php
dieselcruiserhead
The hole cut for the kitchen:
attachment.php
Accuride 500lb ball bearing slides - heavy duty:
attachment.php
Kitchen drawer, all 14 gauge steel (heavy duty):
attachment.php
dieselcruiserhead
Widened fenders:
attachment.php
attachment.php
Tires perfectly fit in the fenders at full compression:
attachment.php
Inside picture of the receiver at the rear:
attachment.php
Lock mechanism for tailgate -- trailer completely locks:
attachment.php
dieselcruiserhead
Paint, black and tan. This is the inside (underside) of the lid:
attachment.php
Rewiring with the original lights:
attachment.php
Tub. Note inside of wheel wells are black:
attachment.php
Body, tub, and fenders. Underside of the tub is ZeroRust black:
attachment.php
Several coats of black on floor of tub:
attachment.php
attachment.php
Kitchen and cooking surface - note the weatherstripping when closed:
attachment.php
Trailer has its own matching keys for the kitchen and lid locking paddle latches:
attachment.php
Hydraulic lifters assist in keeping the lid open even with the heavy Roof Top Tent. Strap assists people of all heights when closing (Scott here is about 5'6" tall). You can open the lid with the tent open as the tent hinge and lid hinge are on the same side.
attachment.php
Photo with tent deployed:
attachment.php
dieselcruiserhead
Heavy duty wiring (6 wires in plastic coated harness):
attachment.php
Final pics / in action:
Breakfast in Valley of the Gods. A stainless cooler fits perfectly infront of the water/fuel cans:
attachment.php
Trailer in tow overlooking Lake Powell:
attachment.php
dieselcruiserhead
From my harddrive (pics I haven't posted yet):
attachment.php
This is in the wash to the west of Comb Ridge, where Everett Reuss' body was found, which is Ute country.
attachment.php
Traditional military lunette which I never had any real problems or complaints with. I may not know what I'm missing though... Trailer tows great on or off road and at all speeds. The way to drive it is as if its not there. It follows you exactly where you are going.
attachment.php
With the tent deployed and the ladder down:
attachment.php
And that's it.... Thanks and sorry for all the pics/slow load...
'05TJLWBRUBY
Sorry to see this up for sale. I enjoy trailer projects and your build was one that I watched in detail. You did an excellent job, I thoroughly enjoyed watching it's progress to completion. A lot of work and detail put into this. Glad you at least got to enjoy a few trips with it. Good luck on the sale.
Best of Luck,
Mike
dieselcruiserhead
Thanks Mike..
As I was going back through the photos I was a little nostalgic and really looking back I was pretty surprised even myself looking at all the attention I put into it. I wish I could keep it (and I could, but it would be a PITA) but unfortunately it doesn't fit right now. There are good chances it will need to spend the winter outside due to lack of space, and frankly will be a few years before I ever really need to use it if at all... So that's sort of what it comes down to. Such is life and it was fun though while I had it..
thanks,
Andre
dieselcruiserhead
A friend has offered to transport it east for me (for probably minimal $$) when he comes through SLC and makes his way to Rochester NY. This will be in a month or two. FYI... thanks, Andre
jmorgg777
I want your trailer. Do you still have it? I am in SoJO, Salt Lake
Gorgeous!!!:) Very interested please call 801-706-7732 if still for sale.
bdpkauai
