Free to a good St Louis home -- Gen 1.5 Tacoma DC Westin side steps -- used takeoffs
4xdog
Some of you may have seen the giveaway of the lift kit and suspension on a new-to-me 2003 Tacoma DC 4WD TRD as I make some upgrades more to my liking. That stuff found a home on here, which makes me happy 'cause otherwise decent stuff isn't getting pitched.
https://www.expeditionportal.com/fo...0-lift-kit-oe-springs-takeoff-for-ome.197623/
The next item on my give-it-away-quick-or-it's-in-the-dumpster list are the Westin Automotive tube side steps on the 2003 Tacoma Double Cab. These are perfectly serviceable, but they have corrosion on the top of the tube around where the flat spots and rubber inserts are fitted. The mounts under the body have corrosion too, as you'd expect. They'd probably clean up OK if someone were interested, and would likely give OK service on a trail rig as is. These are the ones we're talking about (as best I can tell): https://www.westinautomotive.com/signature-3-nerf-step-bars/2003/toyota/tacoma
They're coming off during the week of Labor Day 2018. Holler quick if you'd like them and can pick them up in the Saint Louis area.
