Fridge slide
verdesardog
100# full extension ball bearing slides from Home Depot. 1 1/2" insulation on the sides with cutouts at the rear for ventilation. I also added an external 12v fan controlled by the fridge. I could only fit 20" slides due to cabinet dimensions but the fridge slides out enough to open all the way. The temperature of the sides of the cooler are about 15 degrees cooler than the ambient temp in the trailer so the insulation is doing a good job of reducing the heat load on the fridge.
Swapped out the volt meter for a power meter to better monitor 12v power usage:
With fridge running on shore power:
With fridge running on 12 volts:
empireoverlandza
