modestoman
I have several items that are for pickup only in Denver. Message me and I can send pics. Everything is in excellent condition and comes with hardware.
EASY-OUT AWNING / 2M / BLACK
$175, sells new for $379.00
Always have shelter from the elements with this Easy-Out Awning / 2m, which mounts to your roof rack. When expanded, this awning measures 2m wide and 2.1m out from the vehicle, making it an ideal size for all medium vehicles.
EASY-OUT AWNING BRACKETS
$45, sell new for $89.95
Securely mount the Front Runner Easy-Out Awning, as well as other popular awning brands, to the Slimline II Roof Rack. This no drill, off-road tough mounting solution offers a refined alternative to the ugly and bulky galvanized L brackets.
4"/100MM LED FLOOD LIGHT W/ BRACKET
$65, sells new for $125.00
LED flood light for illumination around vehicle and campsite. Comes standard with Front Runner custom tiltable bracket for fitting to the front, side or rear of the Roof Rack.
HELLA EXTENSION CORD - 3M/10'
$15, sells new for $30.95
A 3m, Hella cord that is used to supply power to your Front Runner LED lights (10"/250mm LED Flood Light w/ Bracket & 4"/100mm LED Flood Light w/ Bracket).
UNDER RACK TABLE BRACKET
$85, sells new for $169.00
Transport your Front Runner Table underneath your roof rack with this noise-free, easy-access solution. These off-road tough brackets can be mounted either parallel or perpendicular to the roof rack's slats giving you the option to access the table from either the side or rear of the vehicle.
FRONT RUNNER OUTFITTERS QUICK RELEASE TENT MOUNT KIT (TBMK011)
$75 comparable sells new for $149.99
Once these brackets are installed on a Front Runner Rack, no tools are needed to remove or install a roof top tent. Simply release the safety catch on the 4 latches and lift the tent away in seconds. No more wrenching in tight spaces. This strong and rattle free mounting system is built off-road tough for use with Front Runner Racks. Works with the Roof Top Tent and other popular soft-shell tent brands like TJM, ARB, Tepui, etc. Works with hard shell tents such as Autohome/Maggionlina, and James Baroud. Four low profile latching brackets bolt to a Front Runner Rack, and 4 self-aligning guide bolts secure to the tent base channels using the supplied nut plates (3 sets of nut plates to work with popular tent channels included)
