FS-1978 TOYOTA FJ40-SUPER- LOW MILEAGE
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1978 TOYOTA FJ 40
22500 MILES
DOWNEY HEADER
HEI IGNITION
HOLLEY CARB
WEIAND INTAKE
Here's a list, with receipts/documentation (over $8000), of all the parts that have been replaced:
5 new tires, 31x10.5x15
5 new hubcaps
New HFS front bumper
New HFS rear bumperettes
New t-case oil
New trans oil
New engine oil-Mobil 1
New differential oil
New WARN premium hubs
New air filter
New fuel pump
New water pump
New gas cap
Carb adj/timing set
New carpet front and rear
New rear cargo mat
New tie rod ends-not installed
New brake master cylinder
New clutch master cylinder
New clutch slave cylinder
New left rear spring seat
New taillight lens, L&R
New ES9000 shocks
New Kenwood stereo USB/MP3/Pandora
New 6x9
New center console
New receiver kit
New dash cover
Ton's of stainless hardware
The truck starts and runs like a 22000 mile truck. There's no smoke at start up and everything works as it should, even the side marker lights. The placard on the glove box is like new and the sticker on the drivers door with instructions on locking the hubs is like new.
The whole inside has been POR15 prior to the carpet installation, I have pics documenting before and after.
I love the diamond plate and NO IT'S NOT HIDING RUST, it's covering an imperfection on the left rear quarter panel, I have pics before and after, not trying to pull a fast one just being 100% honest.. The only rust is a little under each wheel well which is pretty normal from all the one's I've had.
Things I wanted to do but ran out of the desire to do them:
Headliner
Tie rod ends installed, like I said, I have new one's
Repair the rust underneath both rear wheel wells
New window felts in the doors
Rear drivers barn door needs a gasket
This isn't a $40,000 rig, it's a very nice, well restored/maintained rig that will last you a life time. For a few thousand, you could make it a $40,000 rig for the Barrett Auto Auction or some collector.
$21,500 and may consider trades.
Imperfection on left rear quarter panel
Goldenbora
