FS: 1991 FJ80 Land Cruiser $5,000
CA-RJ
Expo Approved™
1991 FJ80 Land Cruiser 212k miles
$5,000 firm
Lots of pictures here
Highlights:
-Purchased in San Diego, CA in 2012
-3FE
-4.88 gears
-ARB air locker in rear axle
-315/75-16 Goodyear Duratracs on OEM steel wheels
-ARB front bumper
-Toyota factory snorkel
-Fox shocks
-Old Man Emu springs
-Dynamat in the complete interior
Things you should know:
-Brakes spongy
-Left rear window regulator is broken. Have replacement with motor included.
-Cruise control does not work
-Upper oil pan gasket leaks
Service History since 2012:
175k- Replaced O2 sensors, installed 4.88 gears, rear ARB locker, front axle rebuilt, speedo cable
replaced. (Yota Masters, Corona, CA)
180k- Replaced front calipers
187k- Replaced starter, trans flush
191k- New 315/75-16 Goodyear Duratracs (4) and Toyota OEM FZJ80 steel wheels
198k- New Man-A-Fre SS brake lines,
198k- Valves adjusted, replaced drive belts, fan clutch and radiator. (Yota Masters, Corona, CA)
205k- Replaced battery, spark plugs, serviced diffs
208k- Replaced steering box (reman), brake booster, brake master cylinder (Anderson Automotive, Olathe, KS)
211k- Replaced B1S1 O2 sensor
Goldenbora
