All aluminum build, Steel frame,independent axles with 5×5.5 lug pattern 18" wheels w_33" tires. 17gal. fresh water tank. On board water pump as well as insta hot water heater for kitchen sink and shower.
Two 10#propane mounts aft on spare tire swing out. 1370# gvw on 3500# independent suspension, axles less.
Plenty of ground clearance. Two burner stove. 90ltr 12v/120v Iceco combo freezer/refrigerator. Twin 90 amp batteries with solar and shore power connectors, and charging. OVS RTT / OVS 270° Batt wing awning. Rear stabilizer jacks, and front jack stand, Lock and Roll 4" higher or lower receiver hitch, and 30" long × 2" receiver tube to connect to trailer. I have drilled 5/8" hole at 24" for off road use.
Happy wheeling
Happy wheeling
