Selling my Alu Cab Canopy Camper Prime set-up for short bed Tacoma. There are fit kits available for SB Colorado and Ranger I believe as well. This is without a doubt the best of the lightweight campers. Its weight is in the sub-450# range. I've just completed the build and have yet to even sleep in it. Life changes are pushing me in a different direction at the moment, and I dont for-see myself getting much opportunity to use it, so better to go onto a new home.
Located in Long Beach CA. Canopy is about 4 months old. Buyers responsibility to arrange for removal and/or transport. It will take a couple hours to remove so you can see how its done. Will go to any local shops for buyers swap
Shadow 270º awning
Stow-away table
Shower frame
internal storage pockets
LED dual color light
LED stalk lights
Rear molle panels
Spare tire carrier
lo-pro roof rails
I have added the following:
PowerTank 10lbs co2 bottle w/ attachments
200 watts Solar Panels
NorthStar AGM 480 217ah battery
Snomaster dual door fridge / freezer
2000W Inverter
DC-DC Charger (charges PV or starter battery as well as can draw from starter when needed to charge house)
USB Charger Ports
Switch-Pro 8100 that controls lights, internal and external.
Custom fabricated power panel that the above items mount to.
Truck is available separately or together as well. Lots of mods there too!
Shadow 270º awning
Stow-away table
Shower frame
LED stalk lights
Rear molle panels
Spare tire carrier
lo-pro roof rails
2000W Inverter
USB Charger Ports
