FS: Eberspacher (Espar) B1L Gasoline 12V Heater Complete w/ Digital Control Airtronic
carl k
SOLD! Here's a used Eberspacher (Espar) BL1 gasoline heater to fit Vans, busses, Westys, Syncros, Dormobiles, or anywhere else you want an auxiliary heater. 1800 watts of heat from this little guy. Runs on gasoline and 12V power (most of the heaters you find on eBay run on diesel). Worked well when removed about 2 years ago, stored until now. This has a nice digital controller/timer with the original fitting brackets. Complete as shown with fuel pump, ducting, wiring, relay, fuel hose, diffuser, etc. Includes detailed instructions in English and German. Heat exchanger has been replaced, so little plastic "pins" that join the two halves of the shell are missing- you can get replacements from Espar or just use small screws. Flexible output duct is squished a bit on one end, and the main power wire has been cut (but you'll probably need a different length anyway.) Only selling because I'm switching to a propane heater. SOLD!
thanks,
Carl
eberspacher01.JPGeberspacher07.JPGeberspacher02.JPGeberspacher03.JPGeberspacher04.JPGeberspacher10.JPG
Goldenbora
