Fs: Extreme aire severe duty compressor
cruiserlarry
One Crazy FJ
Used EXTREME AIRE SEVERE DUTY COMPRESSOR for sale
This compressor is in new condition mechanically - just had it factory rebuilt prior to offering it for sale (it worked fine before - just precautionary).
The ExtremeAire Severe Duty Compressor is setting standards for high output compressors. By utilizing a 3/4 horsepower fan cooled motor, overheating is a thing of the past. Designed to fill the largest 4WD tires or the highest-pressure RV tires, this unit can fill tires continuously with no fear of motor burnout. With a 150psi working pressure, you can fill air tanks and run impact wrenches to dismount and mount wheels easily. For clean air in the dirtiest environments, the ExtremeAire uses an oversize UNI-Filter that is crush proof, washable and reusable.
No other 12-volt compressor has the speed, continuous duty cycle, output, pressure rating, and reliability that the ExtremeAire can deliver.
Tech Specs:
- Continuous duty cycle
- 3/4 horsepower motor
- 30-amp draw at 35psi
- 40-amp draw at 150psi
- 4 cfm free flow rate
- 150psi max working pressure
- Can be mounted upside down
- 14" long, 6" wide, 9", tall
Retail price $414.95
FIRST $200.00 CASH Takes it home !!!
(Shipping /paypal available at additional charge
RocKrawler
Supporting Sponsor
Its a great compressor, extremely dependable, and Larry takes meticulous care of his stuff. I'd buy anything from Larry in full confidence
cruiserlarry
One Crazy FJ
That is not the picture is it?
That is a stock photo from Extreme Aire...The actual compressor is virtually blemish-free (it was repainted to factory color), it has the one way valve and fittings on the output, and the power / ground wires have been shortened
30 - 40 amp draw ?! that seems like a lot for a air compressor. maybe it's just me.
This is a serious compressor w/ a big, reliable motor - big motor = big power draw. In fairness, most larger compressors by Viair and others have similar draws.
Thank you - your check's in the mail :bowdown: :)
Here's a pic of the actual unit:
Goldenbora
