FS: GOBI JK Stealth Lightbar and Wind Deflector-SHREVEPORT, LA
Mayhem-6
I'm changing my setup a bit, going with a different style front lightbar part for my roof rack.
Rack was built/installed late Oct 2009.
Looking for local pick-up/meet only right now. Due to large size, shipping would be difficult/expensive. Check out gobijeep.com or AlphaExpedition.com for more info on Gobi Racks.
I have the Gobi Stealth Lightbar and Wind Deflector I'm selling for only $250!This does not come with the rear part of the roof rack or Q/Ds. Combo sells for ~$400 new on AlphaExpedition and other websites.
Works with JK Jeeps, 2007-2009 w/ Soft Top or 2007-2011 w/ Hard Tops. It won't clear 2010-2011 (with cables) soft tops when raised/lowered.
The rear part of the Gobi Roof Rack and be added later to this lightbar combo if you choose.
No drilling required for install, bolts directly into existing windshield bracket bolts.
Designed to work with all snorkels on market for JK (especially AEV).
Fits 4, 2"x6" (recommended, PIAA 2100 style), 2"x4" or 3"x5" off-road lights
WEBPAGE STUFF:
FEATURES AND BENEFITS:
? Fully welded construction prevents rattleing.
? Pressure tested to eliminate open welds and rusting.
? Fully welded, traversable expanded metal deck for easy loading and securing of loads.
? Gray epoxy powder undercoat rust inhibitor.
? Black powder textured top coat for excellent protection against UV rays and road grime.
? Front light bar supports up to 4 off road lights, available in STEALTH or RANGER versions. Stealth version provides a flat surface structure front to rear along roof rack?s highest surface level. (Great for canoes, boats, bikes, skies and large cargo carriers)
? No Drilling required! Uses existing body and frame mounting holes
? Installation instructions and Specifications available on line at the Gobijeep.com
? All stainless steel and grade 8 hardware used.
? Made in the USA.
PM me if interested!
JSKepler
