FS: Large PTO winch
I have a large PTO winch that I pulled off of a 1968 tow truck a while back. It turns on the bearings well with no discernible slop. It has an unknown gear reduction. It also has the drive chain and PTO shaft. I will see if I can find any more info about it. I will ship at your expense, but it is HEAVY (probably 100lbs!!!). Located in Knoxville, TN. Looking to get $300obo. :elkgrin:
Hill Bill E.
Oath Keeper
Nice! I appears to be a 'Braden', but their name is usaully cast into the end cover.
Does it have a free spool psoition?
Wow! good eye! Yes, "Braden Winch" is stamped into the top of the side cover. It looks like it free spools when the spool is pushed to the left side of the axle (from the picture's POV). On the right side of the axle, against the stand and bearing is a round piece of metal the spool will kinda lock into. When it is there it doesn't freewheel and spins only when you turn the sprocket.
Clemtiger84
