FS: Motorola VHF radios!
viatierra
I used to use these radios for taking groups of newbies out on AZ trails. Here's my Expo Package Deal - $250.00 + shipping:
1-2 watt Motorola MV21CV (I used this for the trail leader)
7-1 watt Motorola MV11C
4-extra batteries
5-wall chargers
These are exactly the same as the radios found in these ebay links. Check them for additional info. My radios are all dark grey, used but in good condition.
This guy wants $99 each, which is crazy since that is nearly what I paid for them a few years ago.
Here is a nice package of 4 and includes specs and info.
I figure that they will fit in 1 Priority Mail box, maybe 2. That will put shipping at 10-20 bucks in the US. If nobody bites, I'll pop them on Ebay this weekend.
Thanks!
LUISJG said:
frequency range?
thanks
I clipped this off of a sale of identical radios on ebay:
MV11C Specifications:
1 Watt output
1 Channel, easily programmable to 1 of 9 VHF frequencies through a voice-prompted menu:
1: 151.625 MHz
2: 151.955 MHz
3: 154.570 MHz
4: 154.600 MHz
5: 151.700 MHz
6: 151.760 MHz
7: 151.820 MHz
8: 151.880 MHz
9: 151.940 MHz
38 "interference eliminator" codes, also programmable through the voice-prompted menu... you'll only hear transmissions from xcvrs set to the same code (this is a squelch bypass and NOT a scrambling or encryption process).
Range:
Up to 4 mile range (line-of-sight, no obstructions)
In steel and concrete buildings, about 125,000 square feet or 6 floors (may vary considerably).
Dimensions:
Body: 5"x2.75"x1.25" (8" tall, including antenna, 2" thick, including belt clip)
Weight, with battery: 10.5 oz.
Battery: 7.5 volt, 600/650 MAh NiCd. Motorola PN HNN9044A (Same as SP10, SP21, P10, etc.)
Wow, that's a lot of communications gear for just a little money.
Someone here is gonna get a great deal.
Motorola makes some of the toughest, most reliable electronics gear you can find. I have always been a huge fan of their quality engineering.
viatierra said:
Okay Ron their on their way. I just missed the 3 o'clock deadline so they are set for delivery on Saturday.
Crud! Office is closed Sat. They should be able to redeliver on Monday I assume?
Wolfbox
