FS: NEW Rock Ware Heavy-Duty Drag Link & Rock Ware Heavy-Duty Offset Tie Rod
1.Rock Ware Heavy-Duty Drag Link (NEW)
The Rock Ware Defender Heavy-Duty Drag Link will fit Defenders only. The Defender Drag Link may be fitted to Disco1s and Range Rover Classics, but only if the pitman arm is replaced with a Defender type and a Defender Cross Rod End is fitted.
Price: $70 obo
2. Rock Ware Heavy-Duty Offset Tie Rod (NEW)
Replace your Defender's weak and vulnerable factory tie rod with the Rock Ware Defender Heavy-Duty Offset Tie Rod, which is both stronger than the factory tie rod and shaped to provide maximum clearance below the front axle. The Rock Ware Defender Heavy-Duty Offset Tie Rod is a drop-in installation in all Defenders, and no vehicle modification is required for a proper installation. The Rock Ware Defender Heavy-Duty Offset Tie Rod will fit Disco1s and Range Rover Classics, but only if the ball joints are changed and the factory steering damper is relocated to the Defender location in front of the axle.
Price: $155 obo
lkretvix
