FS: Toddco Dicovery II extended driveshaft
L
LeoLR
Guest
I have a heavy duty Toddco Suspension driveshaft for the D2 for sale. It came off my old D2 and is in perfect shape. Less than 5k on it. U-joints are tight, no slop. It will fit stock and lifted trucks, up to 5in I believe. Gets rid of the stupid rotoflex coupling. I am wanting $150 shipped to your door.
Here is the shaft
http://toddcosuspensions.com/larodiiifrdr.html
AxeAngel
Sorry, but I am a little bit confused here. The link is for a remanufactured front driveshaft. You mention getting this d-shaft to replace the rotoflex coupling. Only an aftermarket rear driveshaft with the correct flange would do that.
The item you are referring to is a factory front driveshaft that has been rebuilt with greasable u-joints. Additionally, when lifting your truck, you can have the correct length driveshaft built to your specification after taking in the revised geometry from transfer case to diff. This would only come from an aftermarket unit and not the stocker.
Please clarify and I apologize ahead of time if I misread your post and am incorrect.
-Sam
Clemtiger84
