I'm curious if anyone has dealt with this before and can maybe point me in the right direction. My problem is my truck started leaking fuel one day and when I crawled under it to find the leak I could see that the fuel lines are in very bad shape. The bigger problem though is the fitting on the hose coming off the pump is completely seized. I've tried penetrating spray and let it soak but it will not come off and I'm very nervous of applying too much pressure for fear of braking the metal tube coming out of the tank... Is there another way to tackle this problem? I priced out some new pumps but they don't appear to include the metal tubes on top of the tank that have the seized fittings on mine. Basically I'm looking for some suggestions on how to get this fixed...
Thanks for any help you guys can give.
