Fues box and inverter question for Starcraft
WKCwith5
Hey,
My Starcraft pop up truck camper inverter for 12 volt seems to have stopped working. The 30 amp plug in still works and runs the, AC, Fridge and 115 volt outlets. The 12volt lights do not work. So my question is. is it safe to run the AC current since it is on separate breakers and just forget the 12volt system till I can trouble shot after a trip.
poncho62
Sounds like you burnt out a section of the converter that charges the battery supplies 12 volts etc. Happened to me a few years ago, ended up replacing the whole unit.
I take it you do not have a house battery?...If you do, you could charge the battery with a trickle charger and then have lights etc. Also, so later model fridges, water heaters etc require 12 volts to work
Houie
