I'm pondering the construction of my own rock sliders for my OBS Tahoe. The majority of the vehicles I see have the frame mounted ladder types which are either welded or bolted to the frame and they extend outward under the body to protect the sheet metal. something along this type.
However considering my truck has nearly fully depreciated and also the fact I don't mind cutting it, I was thinking about the integral type where you would cut out the rocker and weld in an appropriate sized square tube (say 2"x4" with .120 wall?).
sorta like this, however likely not so high into the door sill
So, ignoring the aspects of painting the rockers after cutting/welding, can anyone shed light on to the cons of building the cut/weld-in rocker replacement rock sliders? It would seem one plus would be the ever so slight height increase with the tubes tucked up as part of the body.
Is there a draw back with supporting the vehicle through the body vs ladder type when getting hung up? I always though the the ladder type were subject to high stress at the frame mounting or also bending of the slider with it extended outward.
Use of hi-lift jack with either type?
Any recommendations on square tubing size for either type? What about for additional round-tube step bar construction?
The welding & fabrication aspects shouldn't be a problem, only deciding on type and tubing dimensions.
Lookin' for guidance.
thanks,
Morgan
thanks,
Morgan
