Fully Loaded OEV Camp X
Dantheglassman
THIS IS THE CAMPER. It's not cheap, its THE BEST slide in camper on the market.
Aventure ready with all the upgrade for practical, comfortable use!
This is a 2020 Overland Adventure Vehicles Camp-X 6.85 model. It is loaded with awesome upgrades inside and out as well as the best factory options! It is in great shape and ready for its new owner! (Upper side boxes available as well!)
2020 Overland Explorer Vehicles Camp-X (with Aluma-Tray Upper side Boxes for the CampX fitment!)
Asking Price: $43,000 firm. (+$4,000 for the side boxes)
Color: White and no OEV/Camp-X graphics
I bought this Camper 2 years ago used and in Exceptional condition. We added upgrades and toured all over the west coast (USA) without issue.
It is meticulously clean and maintained ( I am a CLEAN FREAK when it comes to this... come check it out! )
I LOVE this camper and brand, and am selling to upgrade to a different model camper.
It is READY to drop in and GO... and at this price, with the boxes, you could buy an Alumatray and be at the same price as a new Camp X (now called the Backcountry).
Specs:
External Dimensions: 140” L x 78” W x 62” H (closed) / 84” (open)
Internal Dimensions: 137” L x 74.5” W x 82” H (open)
Powder Coated Aluminum Extrusions
OEV Gen 3 Composite Floor, Walls and Roof (>=R8)
Fire Rated & Insulated Soft Walls (>=R4)
Locking Roof Supports/hinges Front and Back
Gas Struts Assist for Lift
DOT LED Lighting
Dry Weight: 1200 lbs (does not include the weight of the jacks)
Features:
Plumbing/Heating/Cooling:
Truma Aquago Hot Water Heater
Truma Vario Heat w/thermostat
10-speed roof vent w/roller blind
20-Gal freshwater tank w/12v pump
Bullfinch outside shower on the driver side
UPGRADED SINK: ROVOGO 20 x 16 x 9 in. Drop in Kitchen Sink; Stainless Steel. Black Glacier Bay faucet and soap dispenser. Installed professionally by Off-Grid 4x4 in Boulder Colorado)
Dometic Smev cooktop w/flush mount glass top
Electrical:
180 W Solar Panel
200 W Solar Panel (added in 2023 by Off-Grid 4x4 in Boulder Colorado)
USB plug (dual outlet)
12V auxiliary connection
LED entry light
LED interior lighting
Redarc: The Manager 30 w/display
Victron 100Ah AGM battery
Other:
OEV awning mounting kit
OEV Molle rear accessory rack -driver side
OEV Molle rear accessory rack -passenger side
OEV King Bed Extension.
Dometic crx65 built in fridge
Dometic seitz side window
Screen door
Entrance door grab handle
Aluminum propane cabinet w/10 lb bottle + extra 5lb bottle
C-shaped dinette folds down into bed 38”x77”
Marine grade fabrics
3” medium density foam cushions
High traffic grade vinyl flooring
Structural powder coated aluminum interior cabinetry
Fire extinguisher
LP detector
Smoke/CO detector
Thermo break foam kit
Roof rack ready “L” tracking
Custom Options:
All custom options have been installed professionally by Offgrid 4x4 in Boulder Colorado.
Xantrex Prowatt Sw1000 Inverter
WeBoost Drive Reach OTR (Cell Phone Booster)
Baja Designs S2 Sport, Work/Scene, LED, Amber x 4 (lights are installed all around the camper and controlled from inside)
RVLock Keyless Entry Handle (Make your life easier and open the door with a fob or using the keypad.)
SP-9100 Switch Panel Power System (To control the lights, water pump and WeBoost)
Folding Grab/Step x 6 (Installed in the back of the camper and on the solar mounting bracket as handles for easy access to the roof and items mounted on the MOLLE panels)
Custom shelf (Installed inside the “porta potty” cabinet to improve storage. it's easily removable)
Alu Cab 270 Shadoow Awning
Alu-Cab Shower Cube
Wired for Unique Componentry's Starlink roof-top flat mount, including mounting plates for magnetic feet. (Starlink NOT included)
⚠️ Please note the items mounted on the outside of the camper (MaxTrax, Shovel, chainsaw scabbard, and Pull-Pal are NOT included in the sale.
Known Problems
Outside:
Minor scratches here and there because of branches on narrow trails. Nothing serious.
Small bend in the protective front frame of the 270 awning (no change to performance... watch out for trees!)
Broken antenna for WeBoost (we would just remove it, if we were you it has been worthless for us)
Side Boxes (OPTIONAL):
Aluma-tray Upper side boxes for Camp X fitment. Designed to be mounted on the 6.75' AlumaTray.
**AVAILABLE NOW IN VENTURA, CALIFORNIA or wherever ************ 4x4 campers can go.**
20240430_090724-jpg.833452
  • Like
Reactions: mog
WanderingBison
Very nice rig!
I noticed the fold-up steps on the sides of the solar panel and was wondering what they were there for. Inquiring minds want to know ... or at least, my little mind does :)
GLWS!
Dantheglassman
Very nice rig!
GLWS!
Thank you! Yes... These function as grab handles when climbing up on the roof... There are steps on the back, but as you exit onto the roof and more importantly as you work to get back on to the steps, these handles are crucial and allow you to feel and be, totally secure!
We get up there to remove snow for example.
Professionally installed by Off-grid 4x4 (formerly BVO in Boulder)
guapstyle
