Fuse block/relay suppliers?
Czechsix
Watching you from a ridge. In Alaska. I'm cold.
Well, I see slomatt's DIY project to combine a fuse block with relays - but other than scrounging in the junkyard, does anyone know of something like the Blue Seas fuse block that actually has attachment points for relays? Actually, I'm thinking more of something like an OEM system where you just plug the relays into the power distribution/fuse block assembly.
DelCity, Allied, West Marine, Defender, etc - no luck with them.
This is the only relay holder I have found.
http://www.rallylights.com/detail.aspx?ID=772
I plan on getting one. I have a blue sea fuse block that I haven't used yet, its very nice. In the end I went with 2 Painless Wiring fuse blocks. One is under the hood for lighting etc and the other I installed in my center console for interior needs, such as my CB and hardwired gps power cable. When I do the dual batteries I will shift them over to the second battery.
Thanks very much for the links folks, I'm checking on them. I also found some from Painless - dunno how I missed them. One thing that is very interesting, and something I really like about the Painless blocks, are that you can get them in a "weather resistant" format. I'm specifically looking at item #70217, 7 fused circuits/2 40 amp relays.
Heck, even the Blue Seas fuse blocks don't seem to be o-ringed, or dust/water resistant.
THATSALEXUS?...I don't suppose you can comment on the Dill bulkhead connectors, can you? I'm looking at the sealed units, 28 pin or so...
The more I look at the Dill, the more I like what they're capable of.
I just threw an email out to them, asking if they had any more sealed units. Guess I could always use tupperware...sigh. Ghetto. LOL.
My question is what size relays does everyone use? I have seen alot of micro relay blocks but the largest micro I have found is 30A.
empireoverlandza
