Fuso Crew cab 4wd
kerry
Since the US doesn't get a Fuso crew cab 4wd, has anyone considered retrofitting an FG 4wd drivetrain to a 2wd Fuso crew cab? Is it feasible?
I'm sure someone will provide a more detailed explanation, but the simple answer is "not even close".
One reason the FG has doesn't sell very well in the first place is the stepped frame which limits the number of applications it can be easily adapted to.
Be aware that the FE has a straight frame, and the 4x4 FG has a frame that steps down behind the transmission. Here's a photo with the FG close to the camera, and the FE in the background
This difference in frame design may affect the fit of the FE crew cab on the FG.
edit: Hinoranger, you beat me to it!
Chip Haven
ps. want to know the difference between a medium duty truck and a heavy duty one?
Check out the frame on the Fuso FM model, seen beyond the FE in the photo!
good picture, here's the drawings anyway:
http://www.mitfuso.com/pdf/08-FE-BBD-part2.pdf
pg. 25.
fitting a crew cab to a FG chasiss instead might be possible.
Haven, do you know- do the standards for late-model medium duty trucks- the ones that keep them out of the U.S., pertain mainly to emissions? Could a "grey market" truck be legal if an engine with U.S. spec. fuel pump, injectors, exhaust, etc. were installed?
klahanie said:
From the Mitsubishi Australia site:
Here is a chassis drawing of the Fuso(Canter) 4X4; regular and crewwcab.
Although the AU and NA front frame may be different, it looks like the extra length of the crewcab "covers" most of the raised portion of the frame. Leaving aft of cab with flat rails.
:26_34_3:
Don't see many people quoting R.M. Patterson. His 'Dangerous River' which I found in a used bookstore on Queen St. in Toronto in 1978 took me up to the South Nahanni.
"Could a "grey market" truck be legal..."
Well, sure, given unlimited time and money! The major hurdles are emissions controls, crash safety items (airbags, bumpers seat belts), and other safety equipment (lights, tire rims, and so on).
Just getting your truck past USA customs is expensive. You'll have to post an large bond guaranteeing that the vehicle will be brought up to USA specs. If you don't, the feds will confiscate and destroy the vehicle.
It would probably be easier to adapt a USA-legal Fuso FE crew cab body to a USA-legal Fuso FG chassis, even if it involves lots of fabrication of new body mounts and so on.
2WD to 4WD ???
Hi Kerry,
I would think that a cab swap was possible but a lot of work any way you did it. No fabrication but alot of pulling things apart and swapping things around. The chassis are hole punched for mutiple fitments. I'm really supprised that there's no crew cab in the US. If they take off like we're predicting I'm sure the range will be expanded in the near future.
The step is of course to allow for the transfer case clearance and there's now way around that. Not that it's any problem if you use a bit of lateral thinking to keep everything as low as possible. You certainly dont have to have a step in the floor/tray to compensate for it.
Regards
tbnd88
